  • Replies 129
Posted Images
lol, daves tyre was crazy!
Dont forget Victor spinning off the track on those brand new semi's
oh yeah that too! "oh yay i spun again, spinning is the best bit"
crazy little mofo
If all goes to plan i think i will be making a trip to an open day some time in october
crazy little mofo
lol, yeah he's a nutcase
Let me know when - ill come and have a go aswel :(
Nice work Steveo good to hear its back on the road, I hope to have mine done by Xmas.
Should I bring a broom for Wakefield this weekend or will you be able to contain yourself?
Ive got some spare bits left over if you're after any strange bits
Can you bring one please? Dont forget your apron this time :D
i blocked off one of the restrictors only, theres a few rb30's without them that run fine.
Have to wait and see what it will be like with constant high revs
I wouldn't sweat it mate. plenty of high power RB26s running fine without an external oil drain. as long as things are done properly. block off a feed, and get the internal oil returns ported out a bit and cleaned up so they flow more. much easier and seems to work very well. that's what I've done with my donkey. I might still add an external return to be safe, but if you do ad one, try and put it in the right spot. just replacing the rear welsh plug like so many do is not the way to go.
yeh i've also been told since im not running a rb25de i dont have to worry about the extra feed to the head
get my new exhaust mani next week, you should of seem the extent of the cracking in my so called "trust" manifold.
Edited by silver gts-t
OH
MY
GOD!
hahaha very happy for ya mate, i'll have to make a trip to Syd again, I wanna see your beast on the road!
I wouldn't be planning that trip any time soon..... :)
So whats the damage Steveo, anything major?
Dont know yet, its sitting in a garage all dirty - ive got to clean it tonight (or tomorrow) and call the mechanic a bit later today to see about the next step. Id prefer to pull it apart where it is now cause anything out of place......well.......will look clearly out of place, but that may affect the warranty so im not touching it (and neither is anyone else) until i know what will affect the warranty and what wont
OH
MY
GOD!
lol, you missed it - but thanks heaps spanna :)
its a replica of what i had on, just made from 4mm steam pipe instead and as i've been told the collector is bigger etc etc
Sick
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
