We finished 1st in class last time, lets hope the tradition continues :)
hoping to have a 4.3 ratio 2 way diff installed by the day, just waiting on a tailshaft to be made up so it can be fitted.
Racing starts from 12:30pm, and its FREE to come and watch.
https://www.sau.com.au/forums/topic/224244-qr-top-gear-sprints-sat-28th-june/
Just thought I would share some of the things I have experimented with while installing the new 4.3 ratio diff.
The diff itself is a Cusco 2 way clutch type LSD diff (thanks UAS) from an R32 GTR. This should greatly improve acceleration and pulling out of the corners.
In order to fit the diff, I had to ditch my 300ZX TT rear subframe and swap in an NA subframe, due to the GTR diff not being able to be bolted straight up to the TT subframe. Normally, where the subframe mounts onto the bottom of the body, there is about a 5mm gap between the subframe and the body. I have ground down the tops of the subframe bushes so that the subframe sits flush with the body.
This will lower the ride height 5mm, therefore lower the centre of gravity = better handling. This will also make the connection between the body and the subframe more solid = better handling.
Both the new diff and the subframe are lighter than the TT versions so this adds to weight saving goals.
Will have pics soon also showing the new TuneAgent adjustable sway bar link pins.
The proof is in the pudding though and will find out next saturday at QR whether PB will be broken with the new setup.
I may get out there to watch my mate Simon in his Sil80 which is 25 powered. Starting to get the times down to the 57s now which isn't bad for a streeter.
Unfortunately Geoff i have to work on Saturday, so i won't be there. But thanks for the wrap! There's more left in it with the current set-up, i was held up on that 2nd lap you saw on the you tube video by the little Starlet- i almost think i can dip into the 56's on semi's....if i get everything right that is :)
Needs new tyres as well now :)
funny thing is, the competition is just about the same as Sat afternoon sprints, but less cars. so you get more runs in, and less time between runs ;)
we will also be making a video of our AMEC race car, will have 4 cameras posted around the track and 1 in car camera. once edited I will post the vid up :D
I was going to be out there but have the in laws coming so not sure if I can make it now :)
was hoping to see a good turn out
I was there last friday night for the drifts and saw some good driving but hard to get good photos in the dark lol
funny thing is, the competition is just about the same as Sat afternoon sprints, but less cars. so you get more runs in, and less time between runs :P
we will also be making a video of our AMEC race car, will have 4 cameras posted around the track and 1 in car camera. once edited I will post the vid up :O
interested to see how it goes and how quick the fields are.
hopefully its a good day.
I assume top gear is always National?
michael
well unfortunately it wasnt our day today.
the new diff has turned the car into an animal. acceleration is now another level of awesome if it wasnt already before. the car has so much potential now, we were very disappointed it wasnt able to be realised today. the car will really kick ass once I learn how to drive it.
we only managed a warm up lap and a half, a couple of 720s, and a flat spotted tyre from a brake lock up. after that, the new diff started going "clunk clunk clunk".
so we pulled off the tyres and let the car rest for a while and pulled out of the event, only to find that the clunk disappeared next time I drove the car!! weird.
taking no risks I got the car towed back to the shop. the diff is now out of the car, ready to send back to the diff shop to repair it in time for morgan park supersprints next weekend.
michael
You would own 90% of them Mik. I left feeling a little disapointed. Apart from a few tuff cars most of the field is made up of shitbox n/a 4 bangers that wouldnt pull the skin off a rice custard.
There are far better cars to see and run against at Paul's time attack dayz.
I thought the TopGear days are a step up from the Wed/Sat sprints days? Is it all prety much the same cars? Same story with too many cars on the track?
Top Gear sprints have LESS cars than SAS. Thats why I am doing it this year, less waiting around between runs. Didnt get many runs in yesterday though :(
I will be back doing Morgan Park Supersprints in Warwick next weekend.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
