if you look thru a junkmail electronics store booklet, that you find in your mailbox or in the weekend paper occasionaly, you'll see adverts from various manufacturers, selling 1920x1080 true/full HD plasma and lcd.
LCD for computers without doubt, make sure it features low ms, ie 2ms or 5ms.
Plasma for dark rooms and if you watch a lot of sports.
Either or for movies, comes down to the room settings and personal preferrence
Ive got plasma as its a large dark room where it sits, and becomes a feature point of the room. Lcd would have been disapointing in this situation IMO.
My bro and sis'nlaw got a 50" lcd but swapped it for 50" plasma the next week as sports and movies were blurry etc. Im sure it didnt have a low ms count, altough was true hd
  • Replies 102
50" is to small imho.
A common misconception is that bigger is better.... nope!
Ever sat in the front row at the cinema? Its sh*t.
The guide for sizing is that whatever the diagonal screen size you should sit a MINIMUM of three times that distance.
cheers, M.
Interesting thread.
Why did a few of you quickly disregard the Soniq 40" plasma(i think) 1920x1080 with 1 HDMI input
for like $1500
This is what i've been looking at lately.thinking to buy.
the only downfall i see is it only has 1 HDMI input compared to the 2 or 3 on other well known brands
for example a dvd uses approx 720 line images. If your tv has 768 resolution then its a virtual direct display (no scaling involved) however if you feed in a full HD image it must downscale from 1080 to fit 768. This will still give a good quality picture.
A DVD has 576 lines image, the resolution of PAL DVDs are 720x576 (& NTSC DVDs are 720*480), so 576 vertical display resolution, as all sources always quote the vertical display resolution, instead of the horizontal display res (just like 720 is from 1280x720, & 1080 is from 1920x1080).
It can be 576i or 576p depending on wether you set your dvd player to output progressive signal or not (using Component output). Now there are some DVD players (& all Blue Ray players) that have HDMI ouptut & through this it can upscale the 576 image to 720/1080 & filter the image through a hardware digital filter & the resulting picture looks better compared if you directly let the TV expand the image (through other type of connections; composite (ie RCA), S-Video & Component).
A 576i/p (DVD) res is SD & not HD. 720 & 1080 are HD res.
Been muckin about on the net for a while now lol don't you love when the boss is away!
http://www.digitalcentre.com.au/p/455272/s...-hd-bravia.html
This site has crazy prices, offers paypal & apparently realy good reputation. Don't think JB etc can match, but it may be worth a try :(
Mate you should be able to get a Bravia 40" LCD from JB for about 2 grand now... I got mine for about $2,300 earlier this year so they should have come down in price since then... Go Samsung or Sony for LCD, don't bother with yum cha brands IMHO
In fact Harvey Norman have good deals too... my brother in law just got a 46" (bastard had to go bigger than me hehe) for a steal, almost the same price I paid for mine
I wouldn't buy a tv off the net, too hard to get it fixed/replaced if its faulty
yeah you got a problem with JB huh huh :P
LOL nah i completely understand if you tried to get served in the hi fi section, never enough staff and they always busy. Should check out the games dept, that section rocks :P
Flick works for Harvey Norman, Luke works for JB :P Do you guys have price fights :P
I was looking at 42" plasmas a while ago, when they were $2700. Ive heard good things about Kogen actually, anyone had any bad experiences?
sony = #1 brand for lcds, but they are $$$
imo, get a samsung full hd, 100hz screen and u wont be disapointed!! they r the 2nd best brand and easy enough to buy cheep/wholesale here in sa
btw i havent read the whole thread but 100hz doesnt work for pc input, so if ur hooking it up to a pc, forget the 100hz stuff
i'd sugest u do some visual resarech at truscots in the city before making ur purchase tho
Correct... my bad. Just realised I was looking at region 1 disc beforehand!!
But you get the general idea anyhow....
yeah fair call....I didn't think the plasmas could get the same res as the LCD's but I stand corrected.
I just got a bit fired up over that clown's smart attitude from the eastside.....very easy to do when you're 1600km away
you're a tool mate.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
