  • Replies 50
i'm runnin 8.5 +30 professors up front and 9.5 + 30 round back...
thanks to this thread i can really see myself puttin the rears on the front and buyin some 10.5's for the back :banana:
Ok... Got thuy lookin out for 18 x 10.5 + 20's for me...
god i'm an easy sale!
Before u do that you might wanna test fit the rears (9.5 +30) on ur front to make sure they clear ur calipers...most rears are low disk, hence the bigger dish...and probably won't clear ur front calipers...just a thought.
strange that they fit so easily...my 18x9.5 +22's were sticking out of the guards buy about 5mm and needed rolling and some flaring...
you still working at the D.C?
yeh mate, still working in that hell hole!! hoping to get out soon man, yeh with the rears being +30 they sit perfect with the guards. got the suspension fairly stiff, fronts are as hard as they go, pretty much the same with the rears.
yeah that's gonna happen before i commit :blush:
as it is i need a 3mm spacer up front to clear them
not to mention a new diff is more first cab off the rank neway :ph34r:
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
