Do R32 GTST's have a boost fuel cut? My car did it twice this morning but it wont do it any more, I got to servo and found the positive termal wire was loose and i had to move it to get my car to start.
na i odnt think so im running 12 psi on my car with just boltons and never had it cut out
https://www.sau.com.au/forums/topic/224430-rb20-fuel-cut/#findComment-3961488
RB20 ecu's have a mass airflow sensing cut that cuts injector pulse as soon as the AFM reads a given voltage depending on the air flow/rpm range.
typically even with an RB25 turbo it will not hit this unless it is a really cold day. You can have the ecu remapped to fix this and also customise your fuel and timing maps to suit your needs.
https://www.sau.com.au/forums/topic/224430-rb20-fuel-cut/#findComment-3961670
Mine used to hit it running around 15-16psi on the standard r32 turbo on an icy night or morning. :S
Generally up at around 5000rpm.
I then bolted the rb30det in with the stock ecu and it would hit the fuel cut around 6psi at ~3500rpm with the stock rb20det turbo.
https://www.sau.com.au/forums/topic/224430-rb20-fuel-cut/#findComment-3961893
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
