You can get the gear from revolution racegear. Not sure if their in adelaide. Got the adaptor plate (goes on the engine block), the remote oil filter plate (move that pesky filter to a more suitable location) and the cooler from them. Can't remember how much the cooler was but the plates weren't that expensive.
I ended up using another cooler as I need a larger one but you can still get bigger ones there.
Other than that you need to get the lines elsewhere. I got mine from earl's. Braided lines at $90/meter I think..... :confused:
https://www.sau.com.au/forums/topic/22450-oil-coolers/#findComment-481964
Silver-arrowz,
Was that revolution racegear auburn? any rough ideas on the price of the remote oil filter plates? you then had to get the connections and braided lines right?
would you think the setup exceeded $300 for you doing it this way?
https://www.sau.com.au/forums/topic/22450-oil-coolers/#findComment-496313
Yep, in auburn. I think the plates alone were about 70 bucks. Can't remember if that was for both or each. Then the lines were extra. Don't think lines would be very much if it were just for a remote oil filter as you don't require the filter to be relocated far from the original location.
https://www.sau.com.au/forums/topic/22450-oil-coolers/#findComment-496338
