hi sau hp junkies, is any one running a hks 3037 pro s with hks cams and a hpi low mount manifold or some thing like it with a greddy plenum as this will be my next set up as the hks gtrs i am using has become a little to normal for me.would like to know is some one is running similar set up.so i dont have to get into what other mods i have ill post a link.
http://www.skylinesaustralia.com/forums/Mo...tml&hl=gtrs
https://www.sau.com.au/forums/topic/224701-3037-pro-s/
Have you searched???
Didnt think so!
Seriously, use the search, there is hundreds of threads about the 3037 that would atleast have "some" of the info you are looking for.
if you mean your 95 octa tune yes i have looked you should have more than that if you have everything mentioned .....
how about you show me where to find what my question exactly asked.
bits of info don't help im asking about the hole picture.
sorry nizmo freek ive read some of your posts and you don't seem to be the right person to help me so if you can't help don't bother commenting .
please................
Edited by WARLORD
https://www.sau.com.au/forums/topic/224701-3037-pro-s/#findComment-3960014
How about you use the search function instead of asking me and other people to find the answers for you, the info is out there, you just need to learn to search "mate".
please..................
https://www.sau.com.au/forums/topic/224701-3037-pro-s/#findComment-3960222
all i can say is its a lot better turbo to suit your engine then the gtrs.
20 pound will see you past 400hp at the wheels and you will slash seconds off your 0 -180 time.
Do it....
this is what i want to hear,thank you
but will it be as quick as the muppet bus ......lol
https://www.sau.com.au/forums/topic/224701-3037-pro-s/#findComment-3960249
blar blar blar
look at your posts i could say the same for your questions too ..so i guess you could not find anything useful so you wrote crap again ...
blar blar blar
Edited by WARLORD
https://www.sau.com.au/forums/topic/224701-3037-pro-s/#findComment-3960254
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
