ummm that just looks like an aftermarket GT wing with nismo stickers.
that hedious spoiler posted earlier is part of the GTT nismo aero kit and yes it fugly
kinda like the onw you posted. but looks aftermarket. perfer the look of GTT or even better GTR spoliers.
  • Replies 55
Posted Images
stop badmouthin' Nismo spoilers!!!!!!!!!!!!! you just got to get the right one
in any case is that hideous thing in the previous posts really Nismo???????????
if the bl...dy uploads are working (which half the time they are not) then here's a pic of a genuine Nismo spoiler for R34 and its adjustable too- :P
that is hott *drools*
we're saying the factory one is yuk not the others lol
if the bl...dy uploads are working (which half the time they are not) then here's a pic of a genuine Nismo spoiler for R34 and its adjustable too- :happy:
that's just a standard spoiler with adjustable uprights...
banana.gif lol some more lol, and even more lol - no, its actually a purpose made genuine Nismo product fitted in production ( not cobbled up as you try to insinuate) and came all the rest of the genuine Nismo body kit and other genuine Nismo items fitted in production - but hey, you can keep telling yourself whatever you want - its cool by me - he he he !
I'm afraid Mr. Oizo is right in this instance. Its a factory wing with Nismo stands and nismo carbon sides. Quite a few 34s run this setup.
Also you've got an Altia factory option kit, not a nismo kit.
And here's the part # to prove it too 96030-RNR40
http://www.nengun.com/nismo/rear-wing-stay-set
lol what are you bumping for???
lol
i love nice clean lines and am i fan of cars without spoilers.
BUT
an R34 coupe needs a spoiler a GTT or a GTR. i took my wing of my 34 and had it back on the next day. back looks to plain and simple without it.
but ye lower your car and it will look a million bucks.
it definately needs a wing, my car looks so plain without one,
either a GTR wing or a ducktail such as this bomex one;
*the ducktail, not the GT wing* anyone know where i can get one from? :domokun:
wow, A LOT of mis-information in here, to set the record straight...
The fugly spoiler is an Altia spoiler, it comes with the Altia kit which is most commonly referred to as the Nismo kit, which is incorrect. Altia were one of a few companies that received detail drawings of the skyline models before they were released to develop 'sports option' kits at time of sale.
The REAL Nismo kit for the GTT is VERY rare and i can't say i've ever seen a full genuine Nismo kit in the flesh.
To the poster above with the "different" wing mounts, this is IN FACT the Nismo spoiler, the REAL one. It used the stock blade but different mounts.
http://www.nengun.com/nismo/front-indicators-clear-smoked - can't find the kit link, but that's the REAL Nismo front bumper
so what we call here and what most the brokers calls the 'Nismo' kit is in fact Altia. And the dude above actually has the REAL Nismo spoiler but at least the Altia rear bumper. Assuming the mounts are genuine.
Hope that clears everything up.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
