Hey guys,
has any one had any experience with rusty v35 exhausts?
I'm assuming its a common problem..
If not.. should I be worried?
If any one has replaced their exhaust, (with just say stainless steel) how much did it set them back?
Thanks!
Regards
SC
Hi,
I replaced my original exhaust a couple of months ago with a cat back Stillen stainless for $1100 but it was on special at the time. Freight cost $376!!!! The original exhaust was in excellent condition with no corrosion.
Regards
John
Hi,
Regards
John
Thread starter,
Sorry to jack your thread, but JohnR, was that freight from the US? If so, can you please PM me with company details etc as I'm trying to get an zorst from the states at the moment myself but freight has so-far been prohibitively expensive...
Also, does anyone with actual knowledge know whether there is ANY difference between the G35 and V35 when it comes to the exhaust so I don't import a useless exhaust from the US of A?
Cheers.
Edited by Garage Menace
Thread starter,
Cheers.
The only thing to worry about, is that some US exhausts will not fit Coupes which came out with rear active steering. Exhausts such as the HKS Hi Power for example.
How tell if you've got rear active steering? NFI
  • 8 months later...
sorry to bring this up from dead.
I dont seem to be able to find any catback exhaust from australia, which makes me wanna buy from the US now..
Actually was gonna the HKS Hi power, until reading NISMO's post about the rear active steering..
So, what else will fit? Fujitsubo? Borla? APS?
Anyone knows or owns one of those mentioned?
how sure r u, G33K? i really like the hi power, but if it arrives and CANT be put on, i think i gonna cry.. and there is no way to sell it either..
i tried checking hks in japan, somehow the website doesnt show HIPOWER.. only legamax?
Only as sure as the information my Mechanic gave me, www.tunehouse.com.au - give em a call and ask for a quote...
Tell them (Tim GE.33.EK) sent you :blink:
by far the best guys in sydney to help you out with a 350Z/V35 exhaust is Hi tech Mufflers in darlinghurst.... these guys specialise in lambos, porsche's all high end work.... for about $1300 you get a top quality exhaust system..... one that has that euro sound... not a drowing sound that you get from most of the cheap china stuff....
Yeh i agree with V35driver, the owner or the specialist there is pretty much straight up wth you and what they have for you, the material and advise is genuine. you will get quality stuff for what you actually pay for. and with that, have you seen the owners ferrari? its gangsta....
Her ya go my friend. hehehe
http://www.hitechmufflers.com.au/product/i...0Z&b=nissan
they do Cat back exhaust also.
a little different with the V35 from 350z, a little expansion needs to be done (piping) since our cars are a little longer.
we talked about the middle piping before on this thread.
http://www.skylinesaustralia.com/forums/Un...l&hl=Y+pipe
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
