hi guys,
i have a new gizzmo shift light & its too bright for the steering column so im asking for ideas of where else it will work - another member suggested the bottom of the a piller which i think i'll try...
any other ideas out there?
Edited by Marko R1
https://www.sau.com.au/forums/topic/225295-best-place-to-mount-shift-light/
yes i did...the green wire goes on the ecu side of the rpm signal & the blue wire goes on the tacho side of the rpm signal.
you need to physically cut this rpm signal wire so that the actual rpm signal runs like this:
ecu side (rpm signal wire) > green wire > shift light > blue wire > tacho side (rpm signal wire)
the book explains this - this is what i used.
im in syd...little bit far from adelaide
feel free to call me if u need further clarification on 0404884876 or email me [email protected] & i'll email you the wiring diagram which is also shown in the manual (except it doesnt point out the rpm signal wire)
  • 1 year later...
hahaha
ull see soon its in production but basically the triple guage cluster in the middle of the r34 console holds 3 guages (no shit) im gonna make like a lil add on, on the right side of it above where the boost guage is
like another pod for the gizzmo shift light.
im still trying to work it out in terms of electrics to be able to change the shift point easily. (i think i can do it with my wolf v500 but we still working on it)
so after i have worked that part out the fibre glassing bit will be piss easy and it will look intergrated into the dash as well so less noticible to the cops. then ill send it off to china and have it made in carbon fibre.
ill keep u posted
  • 3 weeks later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
