Hey Hey people's, As some of you all know, ive been hell busy on the 33, and i wanted to show every1 whats been happening! coz im really excited about whats been done, and whats about to happen!!! so i thawt ide share it Hahaha!!!
As some of you's can remeber, there wasnt a straight panel on my R33, and the front bar was all mashed up and falling off, and it was about 100 shades of white! and also that it had many engine problems, and the car has never ran right! well, its all changed now!!!! LOL Man im so excited! HAHAHA
Well the engine got a rebuild about 3 months ago, and the coil packs replaced, the intercoola replaced, New bov, some shiney cool pipes, and a new clutch!
As for the body, all dents were bashed out and putty'd over, while that was all happening, i ordered my new BOMEX r34 to suit r33body kit, which has just been put on, and its looks like sex now!!! Haha
And now for he really sik part! I GET PAINTED ON THURSDAY!!! Metallic black with pink flake!
Ino this sounds boring,and your proberly not interested but, i was that excited i just wanted to show everyone the change from all dented up and not running well, to how it is now :)
Here are some " in progress pictures " and some before and after pics. I pick my car up on sunday from paint, and ill take some more pictures of it with the new paint!
Hehehe, so happy with this! Hehe
Pix064.jpg <--- My cutsom boot install LOL
https://www.sau.com.au/forums/topic/225394-sn1p3r-the-building-progress/
Looks fantastic Kel. Cant appreciate it until you see it in the flesh. Cant wait til it gets painted, I'm SOOOOOO coming out cruising afterwards! Cant wait! Wish I had that sort of money :) Mines only a slight rebuild. Oh well.
If you need any help with anything, I'm just around the corner. I'd be willing to help
Where did you end up getting your kit fitted?
My friends fitted it for me!!! They did a sweet job!
Well yesterday at 11am my car was sent off or paint!!! the colour was amazing! and the pink flake looked like fairy dust!!! hahahaha!!! Ill post the new picks up on sunday!!!!
LOL Yes ino P plates are a rare thing to see on my car :/ Now i got Green ones aahahahaha
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
