ok i have a few things for sale that i have accumulated over the last year or so..
OEM nissan front brake pads - coupe
- these are from NON-BREMBO brakes and will fit 03-05 V35's and 350z's
- not sure if they will fit the sedan or not
- they are almost brand new and have been used for only 1 month
- i instaleld them with a set of RDA rotors, and the rotors did not like them at all and squealed. i ended up changing to rb74 pads
- the brake specialist suggests to use these with the stock rotors to get the stock pad performance without squealing
- these were bought new for approx $100 from riverside infiniti in the USA
price: $75 + shipping
OEM V35 coupe rearview mirror
- original rearview mirror from the V35
- removed to fit a homelink mirror
- in perfect condition
price: $30 + shipping
OEM in cabin air filter
- this is the in-cabin filter located behind the glovebox
- removed from my car with 25,000kms to put a new one in it
- condition very good, probably didn't need to install a new one as they looked almost the same!
- bought the new one for $80 shipped from teh USA from riverside infiniti
Xenon-look interior globes
- for the V35 coupe, not sure ifthe same on the sedans
- these are light globes to replace the festoon globes in both the bottom of the doors, and above your head in the centre
- they are designed to give a whiter light than normal yellow bulbs
- not as white as LEDs but have superior reliability to LEDs which are notorious for failing
- bought new from eBay for $50 in a set of other globes
price: $10 + shipping
i might have some more things to add at a later stage. feel free to ask any questions.
pictures are below
I am located in New Farm, Brisbane and am happy to ship anything interstate
cheers,
Warren
https://www.sau.com.au/forums/topic/225430-for-sale-v35-and-350z-items/
Sorry for the naive question, but what nav setup? Is there a way to use the existing screen and have working nav?? Sorry if it's been covered before: I've been busy elsewhere, and haven't checked in for a while...
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
