hey peeps thinking of getting these rimms for my car if they fit.
what do you reckon??from what i remember they measure in at:
front:19x9.5 35+
rear:19x 10.5 35+
and this is the car theyll be goin onto...
oh and any ideas on which rimms u think will look good let me know
cheers
https://www.sau.com.au/forums/topic/225440-yl859-versus-rimms/
yea they look really nice in person. ive tried 18x12 rimms (didnt fit) and 18x11 with a crazy offset of -19 these were about an each too wide. so i was thinkg spacers on these. hopefully there wide enough as i really like the style
are the guards Dmax items? they look freakin sick so does the wheels ;D hehehe
not quite sure what guards they are but definitly not dmax. mine measure 75mm all around or there abouts. ive kinda got my head set on them just hope they fit ok
Yeah those widths are fat but they won't fill the guards with that offset. No worries though, just run spacers and you'll be sweet. More width is even more $$ on tyres. Some 20mm spacers might do the trick?
EDIT: I just re-read your post above about the 18x11 wheels that were an inch too wide with an offset of -19 (!!!). In that case you'll need bigger spacers than 20mm! Those guards obviously flare more than they look to me in the pics.
Edited by HuH
Umm offset? Don't think +35 is gonna look flush. You'll need at least -6 for that to fill anything. And don't buy rims with crap offset with the intention of putting spacers on.
yea thats wat im afraid of.yea the use of spacers is a last resort but just want to make sure to see what they look like.
you need +10 or similar offset with ur guards...
hmm the offset the guy gave me said it was a guess as the 19's arent in the country yet. the offset maybe lower.i know they wont sit flush but will just have to wait and see how they look.
and yea ill post pics when i eventually get them on :D
Why the hell did you bother getting wide guards and then intend on getting wheels that won't fill them at all? It will look like absolute crap. To get those wheels with a +35 offset looking decent, you'd need 100mm spacers and thats just not going to happen.
Those 18x11 -19 wheels will fit with EASE if you stretch some 255 tyres over them. Don't be weak, get them!
just measured the wheels and width today. standard wheels measure 6.5 yea. the width of the guards measure 85mm so thats about 3.5 inches making a total of 10inches wide to fill the guards
or am i missing something here??
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
