as the title states. Can someone tell me what this plug is for? and also what it does. It is located coming out of the fuse box in my r33 skyline. The pic shows where the plug is. I am trying to find this information out because i dont have anything plugged into this socket and would like to know what it is for.
Cheers
Same here. Mines not plugged to anything. It's an open circuit. Where did you get that picture from. It shows something plugged on and going somewhere under the car.
Edited by teng
Looks like my RHF wheel speed sensor harness. Going in the right direction too. Check if you can find a similar one on the other side of the engine bay. It will be mean't to go to the LHF wheel speed sensor.
Hrrmm, duno bout it being the wheel speed sensor, the wheel would come pretty close there.
R32's I know, run the sensor wire through the back side (firewall side) of the strut tower... the driver side one being RIGHT where you'd want to place an ext gate :D
Stick your head in the front wheel well...
Edited by GeeTR
this is what mine looks like in my car. so there is no point looking in the wheel well
You can just see the pplug dangling in the bottom left corner.
Please ignore the red arrow
Edited by jonzie26
its the link for when you want to upgrade to Vtek y0. gives your 200 bazillion trillian kW at the wheels. All nissans have it for when they need to race a honda civic with a k22 VteK forged internals lumpy cams +turbo +supercharger 22psi, 1 wheel drive egg beater.
=D
If its diag, what is plugged into it on jonzie26's pic?
I would like to know as well. If i were him, I would just rip the driver side fender panel and have a look at where the damn wire is going. Take pictures then post it up here :P
Easy as pie.
but.......
The 1st picture isn't jonzie26 car isn't it :(
Edited by teng
but.......
The 1st picture isn't jonzie26 car isn't it :P
haha nope - though he could ask the owner of that car where it goes
he's posted pics in one of the catch can threads in the Fabrication section.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
