hey there,
i have the oppertunity to offer members HID kits at a low price, these kits a plug and play kits and include all the brackets and fittings for fitment.
these are available i a wide colour range - 4300k,5000k,6000k,8000k,10000k,12000k
Picture of the standard Kit:
Picture of the Hi/Lo kit:
Name List:
Bank Details
ANZ
Acc Name. Dion Coulls
BSB . 012551
Acc No. 483047064
Prices.
I will put in a cut off date/time for this group buy so that people will not be waiting for numbers to be filled, once the numbers are sufficient.
But i invite anyone to ask there mates if they are interested in buying also.
PLEASE SPECIFY WHICH BULB TYPE AND TEMPERATURE RATING YOU NEED IN YOUR POST or PM.
If there is 10 or more buyers
1x HID Kit To suit H1/H3/H4(single, Please add $15 for Hi/Lo option)/H7/H11/HB3/HB4/9007
Including Postage ANYWHERE in Australia
$ 170.
25 or more
$ 160.
and if it reaches 50 sets or more
$ 155.
I can supply White T10 Wedge parkers for aditional $10 / pair
If there are any issues with the kits I will do my best to replace parts under warranty just the shipping to and forth can take up considerable time if there is any failure to the parts.
If you have any questions or quieries dont hesitate to ask
https://www.sau.com.au/forums/topic/225507-hid-kit-group-buy/
  • Replies 129
i have this same Kit from a group buy on the R31skylineclub Angry ran that group buy im sure youve got the same contact,
any ways top kit looks great :) if that helps anyone decide out the quality
Yeah i seen his group buy there but i didnt want to cut his grass, mine are cheaper to :cool:
and Whyallapunk, im not to sure i think it depends on the year of your R32 to which globes you have
i dont know that there any good for parkers i have a bunch of those already maybe i should try one out
why i say there no good id LED isnt multi directional beam i have these in atm but want something brighter
but want something like this
Min maybe we can combine shipping and when we catch up next i can give your your globes
go out and pop your bonnet on top of your lights should tell you what type that are and there wattage
ah good point i don't want another kit for my high beams so i can run a relay and have 4x HID power muhahahahaa but yeah that wont be too soon as doing a clutch and install then other things first
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
