The list, i think the easyer way to do this since i cant edit the first post would be to copy the list and add your name to it and your order(remember to specify what globe type and the K rating)
Whyallapunk - awaiting globe conformation
DRF72 - H4 HI/LO + parkers waiting on K rating
Min_R32 - awaiting globe conformation + parkers
Madaz - parkers
krzysis - awaiting globe conformation + parkers 10000k
Nismo_God -
Hey!
I am keen on H1 kit 8000K with parkers as well :(
Looking at the 10000k, how blue would they be on the road?
  • Replies 129
Madaz - parkers
Nismo_God -
Secret32 - H1 8000k + parkers
Greylock - H3 8000k
HI2U - H1 waiting on K rating
6000k is the recommended it a white light whilst retaining the maximum distance and visablility, the further up you go the bluer the light and the less D&V you have. 10000k would fairly blue but not soo blue that you cant see...if that makes sence lol
my personally opinion is 10000k would be too blue for street use
i am running 6000k and thats perfect a very nice white light and all street signs are very well light up
yeah my mate has 8000k and the cops can spot you from a mile away
ill take 6000k and the parkers
I do believe you have all been successful in scaring me away from the 8000K.
WKD-031 can you please change my order to a 'safe' 6000K?.... lol
Thanks heaps guys :)
Done and done :D
Madaz - parkers
Nismo_God -
Secret32 - H1 6000k + parkers
Greylock - H3 8000k
HI2U - H1 6000k + parkers
ive been running the 8000k in my R33 for about 6 months now and cops havent said a word about them...... possibly looking at a 6000k set for my high beams..... will keep u posted
you make the 10th person, ive spoken to the supplier and he has given them to me for a bit cheaper so i will start them of now at $160 instead of reaching 25 so payments can start being made.
Hey!
Have just made full payment of $175=globes($160)+parkers($15)
Should have it in the next day or so as I bank with Westpac.
I put secret32 as the payment description to make it easier for you to locate it on your bank statement :D
I will PM you my address in a moment
Thanks heaps for organising this GB!
Hey!
I put secret32 as the payment description to make it easier for you to locate it on your bank statement :P
no worries, i will let you know when the payment is recieved
you said these kits are a direct plug and play, but do you still have to modify the rear housing cover to fit? i have a r33, and some (maybe most) kits need the rear housing cover to be drilled out bigger to fit the globe in.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
