  • Replies 50
Well I finaly had a chance to start this on the weekend. Will hopefully have a ruff cost on the complete loom with in a month if all things go to plan.
How has yours gone Dane?? Anything you didnt like or would change with it?? Any suggestions you make can only help me with the design of mine one.
Cheers
Ross
Hey Ross, still stripping out the loom mate, haven't had much time to work on it of late. We should have it out this week, and then we can start work on getting the new loom in place. I'll keep you posted mate
  • 5 weeks later...
Ok to bring everyone up to date and revive a now aging thread.
I have been on holidays for a while and just have got back (including a name change). Yesterday i removed the last of the wiring and will be now able to work out the cost of the new loom very soon.
As for my car the loom/s will be completely different due to a few things i am doing but i will post pic etc oncw it is done.
Dis you end up getting your done Dane??
Cheers
Ross
I saw that the other day, ill take a photo of the r32 one this weekend. At the moment the only looms that i wont be doing is the ecu (will get done when i go after market) and the doors untill i figure what i am doing with them (manual winders or fixed). Speaking of which does anyone know if you can get a manual window winder kit for any of the imports?? I know i have seen a few car in japan with manual winder but they might be an in house only kit.
Cheers
Ross
Well here we are, got the last of the loom out and weighed - 13kg of wire (scale is about 500g out so its closer to 13.5). Keep in mind this does not include the looms from either door or the ecu to engine loom which should be another 6kg or so.
Once i have got rid of everything not needed ill weight them again and see the difference. If everthing is working ok ill start the new custom loom made from the teflon wire and we will see what the difference is again, hopefully it will be worth the effort. :banana:
Here is what the mess looked like and ill take a photo once it is cleaned up.
Cheers
Ross
  • 4 months later...
I made a half custom/half modded stocker for my s13 over christmas. It was so much fun i never want to do it again :blush:
Relocated factory main fuse box into the cabin (on the tunnel under the dash)
replaced factory interior fuse box with an after market 8 fuse unit
completely remade the alternator/starter loom
modded the engine loom to get power at new fuse box location so removed a heap of wiring from the engine bay
modded the wiper loom in the same way as the s13 runs it all around the front of the car stock
redid the tail lights with 7 core trailer wire, ditto the fronts (headlights to be replaced so not hooked up currently)
redid the power windows with 4 relays and a couple of switches so now there's only 2 wires running to each door.
In all seriousness, the biggest pain when doing mine was retaining the factory switch gear for headlights, wipers and indicators as there is a heap of wires there and the lengths all needed to be changed. I also kept hazards as it's part of the indicator loom and i figure it's nice to have them if you're crawling back to the pits with issues.
Work in progress shot. I was really over it by this stage (about 3 days in)
It'd also be a lot tidier if i didn't have future boost controller and boost gauge wiring already hooked in.
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
