hey SAU,
just read through an old thread http://www.skylinesaustralia.com/forums/In...c-s-t99783.html about installing a greddy profec B spec 2 into an R33...
Im guna try and do mine this weekend and just needed a bit of help...i think all i have to do is connect ign 12v to the main unit+tap into the fuel pressure regulator hose+mount the soliniod as close to the turbo and run the wires from the main unit to the soliniod......Then its THE BIT IM STUCK ON, how to do the actuator hoses.
DO I:
- just take the line off the actuator and put it into the NO then out of the COM onto the actuator?thats what it says in the manual but is it the same for the r33 (do i have to plug up the intake like in the manual?where is that?do i have to do anything to the stock solinoid/hoses not used?)
Does anyone have Pics at all??
Any Help Would Be Great!
Dan.
https://www.sau.com.au/forums/topic/225634-urgent-need-help/
yeh just follow the manual dude, tis what i did and mine works mint.
i know in the mannual it says to have the other hose goin on to a preassure source ie on the intercooler pipping but u can just connect it to where the actuator hose went :O
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
