  • Replies 45
Umm, guys, just thought I'd say something, the original manifold keeps being referred to as "stock extractors". They aren't, the original one is just a cast iron exhaust manifold. Extractors are as the Coby ones- e.g tubular, better flow than stock. Actualy, "Tube Headers" is more accurate as a term, as extractors are really only a particular design of tubular headers which act to "extract" gas from the cylinder by clever use of cylinder pulses.
cheers,
floody
  • 4 weeks later...
hey guys, i've finally fitted the coby extractors on the car. cost $99. car is much more responsive from around 2500 rpm. i've ended up taking the pod filter off and putting the stock box on with trust panel filter, the sound is soo lound with the pod on!
only prob i have now is that for some reason it hangs low like dogs balls and scrapes on my driveway :P not sure which part exactly is scraping, i suspect its the part where it bends. gotta get outta the car and have a proper look.
hey denny,
its weird, my fuel economy slightly improved?! the extractors do hang quite low don't they, it makes me reluctant to lower my car.
i will organise that dyno day we spoke about as soon as i finish my exams (november 10) so a few of us n/a guys can compare numbers and not feel uncomfortable about the big numbers the turbos pull :( is there anything to 'tune' on a standard skyline? i was told u need at least SAFC or something before dyno tuning is worthwhile?
cheers
greg
hey greg, with a standard skyline i guess all they can do is advance the ignition timing. i've actually got the old school generation 1 safc, the one with the knobs on it lol. theres only like 5 tuning points though. i picked it up really cheap so thought might as well give it a try. anyone else got ? u can turn it up -30 or +30, i take it when u go towards minus thats leaning it out?
only prob i have now is that for some reason it hangs low like dogs balls and scrapes on my driveway :)  not sure which part exactly is scraping, i suspect its the part where it bends.  gotta get outta the car and have a proper look.
they only cost $99?? what the fudge?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
