how much cash plus trade?
when does it see full boost?
would it be in comparison to a 2835s or a hks 3037s?
cheers.
Depending on the condition/year of the your turbo (must be gtt obviously), around $2.6k cash (no delivery). That includes your stock turbo, manifold, dump pipe, front pipe.
This T67 turbo is rated at 400-550ps so I'd say hks 3037s.
http://www.trust-power.com/overseas/englis...bine/020304.htm
Cheers
  • Replies 42
Why can't I edit the first post? Anyway, I received many PMs offering to trade stock turbo with this kit plus cash. So the new deal is,
Greddy/Trust - T67/TD-06SH25G Turbo Kit
*T67, Compression Housing 25G, Exhaust Housing 10.0cm2
*Trust RB20/25 High Mount Exhaust Manifold
*Hypertune custom Stainless 3" Heat-Wrapped Dump Pipe + Front Pipe.
*Tial - 44mm External Wastegate 10psi Spring
$3200 delivered!
or
Exchange with your factory turbo, manifold, dump and front pipe, + $2600 cash. Pick up only.
Also have a power fc for sale. Need exchange with stock ecu.
More items,
Nismo R34 GTT 300km/h Combo Meter (24000km on the clock) $350 (exchange with stock unit)
Nismo R34GTT Console Gauge Cluster $200
More items,
Nismo R34 GTT 300km/h Combo Meter (22000km) $350 Firm (exchange with stock unit, must be under 80kkm)
Pm me your bank details so that i can deposit the money for the Cusco brake cylinder stopper.
i have a stock r34 unit but it has 116xxx on the clock, pm if interested...
Edited by R34GTFOUR
G'day mate how you doin? I'm realy intrested in your turbo kit if its still available. Please let me know asap. I can pick it up and pay you cash or by check if we can make a deal. And also is the 300k meter still available? thanx.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
