how much cash plus trade?
when does it see full boost?
would it be in comparison to a 2835s or a hks 3037s?
cheers.
Depending on the condition/year of the your turbo (must be gtt obviously), around $2.6k cash (no delivery). That includes your stock turbo, manifold, dump pipe, front pipe.
This T67 turbo is rated at 400-550ps so I'd say hks 3037s.
http://www.trust-power.com/overseas/englis...bine/020304.htm
Cheers
  • Replies 42
Why can't I edit the first post? Anyway, I received many PMs offering to trade stock turbo with this kit plus cash. So the new deal is,
Greddy/Trust - T67/TD-06SH25G Turbo Kit
*T67, Compression Housing 25G, Exhaust Housing 10.0cm2
*Trust RB20/25 High Mount Exhaust Manifold
*Hypertune custom Stainless 3" Heat-Wrapped Dump Pipe + Front Pipe.
*Tial - 44mm External Wastegate 10psi Spring
$3200 delivered!
or
Exchange with your factory turbo, manifold, dump and front pipe, + $2600 cash. Pick up only.
Also have a power fc for sale. Need exchange with stock ecu.
More items,
Nismo R34 GTT 300km/h Combo Meter (24000km on the clock) $350 (exchange with stock unit)
Nismo R34GTT Console Gauge Cluster $200
More items,
Nismo R34 GTT 300km/h Combo Meter (22000km) $350 Firm (exchange with stock unit, must be under 80kkm)
Pm me your bank details so that i can deposit the money for the Cusco brake cylinder stopper.
i have a stock r34 unit but it has 116xxx on the clock, pm if interested...
Edited by R34GTFOUR
G'day mate how you doin? I'm realy intrested in your turbo kit if its still available. Please let me know asap. I can pick it up and pay you cash or by check if we can make a deal. And also is the 300k meter still available? thanx.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
