ok this has happened to me twice now.
first time was at the bunnings carpark. cruising at like 20, about to turn into a parking spot, then all of the sudden i loose all power. steering locks up, eninge dies, electrics all flick down to accessories mode. i start it up again and proceed into my spot...
second time, approaching a roundabout, coming down from 2nd to 1st, i loose all power again. start it up again and lurch through the roundabout embarased (as you would be) interesting thing is this time i starteed, one of my belts proceeds to scream at me. this usually occurs when its been extremely cold (frost etc) not sure which belt it is, but its damn annoying, did it to me just before outside work.
mind you both these times i had the clutch fully engaged, so its not like i noobly stalled it.
now.
this is really lame. and it wouldnt help that as im writing this i had a shit day at work. but point is. im really getting frustrated of both these problems
any ideas as to what either of these problems might be?
cheers...
Edited by G0DZLR
https://www.sau.com.au/forums/topic/225893-power-loss/
hi i too have had this same problem ony difference is my cars an auto.. just cruising along at around 20km and then car just shuts off.. done it to me one day at a round about then 5 days later it did it 5 times.. touch wood it hasnt done it since but ive asked mechanics and they have no idea what it could be. i had my computer scanned but they found no error codes in it...
would also like some help on this incase it does it again.
jake
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3978093
now.
cheers...
In regards to the screeching belt. I have a strong feeling it is your alternator belt, I had the same problem, it is due to the excessive drain on the battery on cold days, therefore making the alternator harder to spin. Check you tentioners or even replace the belt if it looks worn.
In regards to the car stalling (I'm assuming you are applying the brakes when the stalling occurs) - check your brake booster vacum hose (and all other vacum hoses to be on the safe side), there could be a vacum leak or even the brake booster itself. (I had a similar issue in my old Bluebird, however the brake booster diaphram was busted).
just remembered - Also check you AFM (seems to be the problem in quite a few scenarios in previous posts)
Hope this helps.
Cheers
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3978210
check your battery etc connections too... i had a similar prob last week over going over the mother of all bumps. thanks dept of main roads...
(also killed a head light bulb)
i forgot to mention, the time i was at bunnings, id just gone over a couple of BRUTAL speed bumps, so maybe thats it. but i think its either that or the AFM, or alternator. either way i think i should get the belts replaced...my cars done 88,000ks, i know that belts get replaced at the 100,000k service, would it be worth getting them done at 90 instead?
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3978595
Yeh I had these problems before when I just bought my car. Scared the sh*t out of me because I thought I bought a dud car. Plus it was my first time taking the car out by myself, so when I asked my mates, they thought that I just didn't press the clutch, which obviously I did.
Anyways, it turned out to be the AAC valve. Takes a few hours and straight away the car was running smoother at idle and never stalled again.
On a side note, the link for the AAC valve cleaning should be stickied or something because a lot of people seem to have this issue and not know how to fix it.
Anyways, enjoy.
http://www.skylinesaustralia.com/forums/Di...mp;hl=aac+valve
Edited by mjscar
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3978649
Anyways, enjoy.
thanks for that mate! i may try this as one possibility, couldn't hurt to do it anyway seeing as my car is 14yrs old after all..pitty most of the pics dont work..
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3979175
It doesn't hurt to change the belts a little earlier :D - You get a little peice of mind and the screeching is likely to go away too.
Sometimes it is not the number of Ks the car has done, but the age - as all rubber degrades over time.
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3980365
do you remember which fuse it was that blew?
It was a RED one in the little kick pannel near the steering collum.
It was a fuse for;
Alturnator
revers lights
something
something
something
It ran a bucket load of things.. but have a look, may be worth it.. the huge speed pump may have loosened one of the fuses to which the cor does not agree with..
Edited by GTS4WD
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3981479
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
