im gonna head up to doncaster at bout 2am 2:30am ish and i think b3za is comming too and gonna try go from that end and see how far we can get as i rang eastlink information centre and they said it will be opened up in sections so fingers crossed
https://www.sau.com.au/forums/topic/225906-eastlink/#findComment-3978035
saw a report on the new tonight that different people from eastlink are giving different times, some are saying midnight, some 8am some midday, there speculating that there trying to confuse people so they dont turn up all at once and cause a traffic nightmare.
https://www.sau.com.au/forums/topic/225906-eastlink/#findComment-3978120
Yer im gonna be heading down with bez aswell, might try convince leigh to wake up and come too. :laugh:
Is matt gonna come for once?
https://www.sau.com.au/forums/topic/225906-eastlink/#findComment-3978161
i just came home then and im off Jacksons
Freeway from Wellington was ROOOTED!!!! backed down to one lane what a joke... Better be open tomoz morning i need to go to doncaster and that will get me there quicker :D
I would take a helicopter tomorrow Mav..
3 million victorians will be on the road in the morning all wanting to be the first to use Eastlink
https://www.sau.com.au/forums/topic/225906-eastlink/#findComment-3978366
i just got off it IT WAS MAD!! went with CAJFLY & Leigh! and few other mates woo im representing skyline first on at the highstreet entrance with about 2-3 skylines behind me haha. cops were everywhere. and i loved the cop convoy leading at front!
https://www.sau.com.au/forums/topic/225906-eastlink/#findComment-3978376
yeh wasnt bad saw a few police cars on my way home from high street there was a sculpture on the right of sum green thing and there was an under cover cop car sitting behind it. .... its all good as long as u dont go over 100 as police are everywhere. i think a few cars got a bit peed off with 3 skylines side by side taking up the whole free way a few times. lol
https://www.sau.com.au/forums/topic/225906-eastlink/#findComment-3978381
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
