  • 3 weeks later...
  • Replies 48
Any luck on this Cubes?
Do you have a link to Tighe cams also? Am trying to sort some out at the moment. 272 degree with 9.5 lift can apparently be done on a regrind, whilst Kelfords who build some impressive cams suggest welding to a camshaft isnt at all good.
yeah they turned out good.
We haven't played with the cam gears as it wasn't able to hold more than 17psi up top.
The same thing occurred before the cams so I'm putting it down to either the FMIC with its 2" piping and or a weak actuator that is quite lazy. Most likely the later.
Mine haven't been built up as they were GTR sticks. The Rb25 sticks apparently do have to be built up.
It went on to make.
3k - forget? :O
3.5k - 200rwkw
4k - 256rwkw
5k - 288rwkw
6k - 302rwkw
7k - 290rwkw
Its awesome to drive. Third gear at 60km/h slightly flick the brake and its up making 19psi and then storms off quite a strange feeling with the motor not reving but your being sunk in to the seat hard.
I was a little off with my overlap calcs. Its actually running around 39degree's overlap so not all that good for top end 'apparently'.
I'll get it on the dyno once I fit an 18psi actuator and new fmic with 2.5" piping and play with the cam gears to shift peak power ~500rpm higher and then stretch its legs slightly to ~7300rpm.
Fuel economy has slightly improved; we spent a little more time on the accelerator injection time and tweaked the afr's.
Sounds really good mate.
GTR cams people here still want 300+ for so i think a set of billets from Greenline etc may eventually work out cheaper by the time they get the regrind treatment.
My thing should be going in the next 3 or so weeks so will consider a new cam come full tune time.
Couldnt find an rbcam on tighe cams website.
Have you heard anything re weld on tips being dodgy at all?
Will look forward to seeing the results. Lith mentioned to me a while back you were having a few issues since the cam install. Dont think that 2" piping could help, not the actuator.
Edited by SirRacer
Bugger.. I have seen a few sets go for 60-100. I picked mine up for 60.
Ebay is another place to look.
Tighe haven't updated their website for a bit by the looks so chances are it won't be there.
Not sure exactly what the problem is.. FMIC is first so I'll know soon enough :(
If not done right building up the cam can be dodgy. Not sure.. If you can't grab a reasonably priced set of gtr cams then by all means grab a set of cams from nengun. :)
$300 for a pair of stock cams is dreaming. What are they useful for lol.
Hi Guys,
just a quick question.
i have a R32 rb25de head with no cams and was thinking of getting the following:
2202-RN170, IN (256deg) (Lift 8.8) (valve timing 110)
2202-RN175, EX (264deg) (Lift 9.0) (valve timing 115)
what are your ideas on how these will go on a RB30/25 build
  • 2 months later...
hey guys
instead of starting another cam choice thread what are you opinions of different sized inlet and exhaust cams.
looking at the HKS step 2 cams. will only be reving to 7k but will have an 8k limiter for power runs and drags.
however car will be more of a daily, just want that phat idol...
was first going to go with the 272 10.2 inlet and a 280 10.20 but am thinking the 280 will be bring power on too late. or should i stick with both at 272 10.2??
turbo will be a gt35r at 1.5bar undecided rear housing.
obviusly springs will be upgraded to suit but will the head need modifing to drop these bad boys in.
I believe there is an 806C grind. Not sure on its specifics but thats where it ends.
More than a 265 duration and 9mm lift and you need valve springs, you'll need to machine the buckets.
Rip the head off spend $300 on a set of valve springs, machine the buckets and drop in a set of 10.5mm lift cams. :(
I probably wouldn't bother regrinding a set of pon cams as you can still fetch good $$ for them s/h and then put a few hundred towards a new set imported from nengun or the likes.
A set of cams from Nengun are worth 800 odd delivered depending on brand.
Where can i get a set of valve springs for $300?
Oh and by the way, I'm using some Gibson Motorsport cams( same as the Winfield GTR). Just had them cam doctored.
At advertised duration
Inlet 256 @ 9.5mm lift
Exhaust 278 @ 9.75 mm lift
...don't tell to many people :(
Edited by BoostdR
...don't tell to many people :P
Interesting aswel they have such a large difference between duration for in and ex
Are you in Sydney? I would very much appreciate the chance to see how it goes with your turbo setup. Its the same as mine expect for cams, ive got 270 10.25 in and out :D
hey guys
any opinions out there. is 280 to big for my rev limit
Interesting you guys dont go for cosworth springs, good for 12mm lift and 400USD a set so compared to 12mm capable springs from japan they're about a third of the price
the guy i get to do my cylinderhead work doesnt like the jun (cosworth) springs as they dont have much tension. his pick are some dual psi springs, second to them the supertech springs
  • 3 weeks later...
  • 3 months later...
Awesome.. Allways been curious what cam specs they ran.
QLD Performance Springs :cool:http://www.performancesprings.com.au/
how do these springs compare to the likes of japanese brands, i.e. tomei?
...Mr 'N1GTR' - can u send the link of these cosworth springs u mentioned in this thread?
Edited by Marko R1
the psi springs (i think they are the same as the performancesprings) are rated as the bees knees in the top end springs (dual coil) by my head guy, jhh performance. its the quality of the wire used makes them good as they can happily sustain all the requirements of a high revving high load valvetrain. the daul springs arent cheap though and not really needed unless ur going to competatively race it, id look at some supertech or ferrea springs or the cheaper single coil psi spring
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
