Yeah. 9 years part time = 4.5 years full time. That sounds about right.
I went to UniSA city west and finished my Bachelor of Business and Economics. It was a long haul, but worth the "piece of paper" in the end.
Seriously tho, there are so many thick people that shouldn't be in uni. And Campus Central f**ked up enrolments EVERY year! :)
9 years - 3 deferred = 6 years
6 years part time = 3 years full time and I'm doing the last year full time to get it finished.
You now have to enrol on line which makes it alto easier. My first year at uni was the last year where you had to enrol at campus central, but yes it was a bit of a head f*#k.
Adelaide uni- B.E. Automotive/Mechanical-god it shits me to tears sometimes! in 3rd yr (from 3)-on track to finish on time hopefully....
Doing 10hr days of study atm for exams-god i wonder why i ever bothered with this course! End Rant haha
Edited by R32Abuser
yeh i go to city west campus at unisa!! bachelor of hospitality and tourism management! its pretty good so far.. only got a couple of days per week...
i agree with ruby, campus central still isnt much better!!! stuffed up my deferral, i wouldnt have been in uni if i hadnt chased it up!
Seriously tho, there are so many thick people that shouldn't be in uni. And Campus Central f**ked up enrolments EVERY year! :miner:
Oh yeah Rueben. You don't even want to know the amount of times we had job applications at the ISP I worked at from Uni CS graduates. You'd ask them to demonstrate how to set up a dial up network connection. They'd ask 'Wheres the wizard?'....
Programmers != support.
Mind you MSCE's are just as bad. Had one apply who didnt know what DNS was. Needless to say, neither of them got jobs.
-D
Yeh im doing Architecture and im in Second year
NO EXAMS but i do build little scale models of buildings, bridges etc
Just starting doing photoshop shit, hopefully i'll get good at it and can make my car look good online haha :miner:
heyy im at uni sa city west tooo
in my first year doing administrative management
dont mind it but im over exams lol
LOL. Been there done that!
Try not to fall asleep during the Marketing lectures :P
Try to get Ken Adams for the economics classes/lectures. He's the one to see for a high pass.
Just starting doing photoshop shit, hopefully i'll get good at it and can make my car look good online haha :P
I did Architecture at Adelaide Uni... It seemed relatively easy from beginning, but I didn't like it and dropped out after semester one. It just wasn't for me...
As of today I'm still trying to decide what to do with my life... :P
Edited by Rocky88
he's good for entertainment value to, friggen phyco ive got him going nutz recorded on my phone funniest + weirdest was when he said he was getting aroused when linking all the theorys together. i hear he's just as nutz on the dvd's but i aint seen em yet.
he's good when ya falling asleep cause he'll just start yelling all of a sudden n itll wake ya up :P
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
