ok ive upgraded my turbos, and now have my old ones in the store room.. i found that they both have a letter 'S' hand written on them..
when i bought my car, it seemed completely standard, and to write on the turbos, the turbos would have have to be taken out sometime.. so now im thinking whether i have standard turbos or not.. how do i identify what turbos i have? i know they are Garrett..
markings on it say - "GARRETT A/R42 M24 1-2" and .42 on one of the tubes and 4685 on the side and
"GARRETT 485" .48 on the other (darker one) i hope u get what im saying here =/
a plate on it says
"UD 1429J
14411-05U20
466071-2"
can anyone let me know what turbos i have? and how would i know if they are 'steel wheeled' turbos? thanks in advance
https://www.sau.com.au/forums/topic/226205-turbo-identifcation-r32-gtr/
They are standard size housings, I can tell you that much. the 42 or .42 is the A/R of the front housing and the 0.48 is the rear. the "14411-05U20" is a nissan part number, so they are a nissan turbo, and given the housings sizes are standard I would say they are stock. It's possible they have been rebuilt, and perhaps given steel wheels, but also possible they were just removed for some other reason and re-fitted at some point.
cool, thanks for the info, but is there some way to tell if they are steel wheeled? i cant think of a reason why they would take it off (unless they blew) and write an 'S' on both turbos.. unless its steel wheeled, maybe its just wishful thinking, but is there a way to be sure?? thanks
Take a photo looking in at the front and rear of the turbo, close enough to see easily the shaft at each end clearly. post it up here and it won't take much.
i can get the front shaft but the back has the dumps attatched at they are really tightly bolted on, ill get u the front shaft pics for now, back in 5~
if theres one thing ive learnt with imports is
dont trust the work unless u do it urself..
my car was suppose to be stock when i bought it.. made 296awkw... i thought instantly.. cant be stock turbos
and sure enough they werent stock.. they had a fairly large compwheel..
but ceramic exhaust wheel... so @ 18psi 1 snapped off and destroyed the motor
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
