yes that is valid, except looking at torque curves vs rpm is just as good a comparison as road speed imo.
But who cares what rpm things happen. You want to know what road speed its happening. No point in a guy grabbing the same turbo setup as me and expecting my results if he has std diff ratio, R33 gearbox and 19" wheels. The rpm he makes the power may be similar, but the road speed will be way different, with my car actually making loads more power sooner and leaving him for dead from a rolling start at 80km/h, or from corner exit of a 90km/h corner.
You need to look at what road speed you are getting the job done. It often highlights that no matter how small and responsive your turbo, and compromised top end. You may still end up with crappy power delivery coming out of a corner at 90km/h. Its smarter to drop wheel size or increse wheel size, or change diff ratio so that you can make way more top end power and still have usable power at corner exits.
The original poster is talking about using the 20 for motorsports...so gearing and where your power hits the road is more important then looking at the motor in isolation.
Most already apprecaite the subtle difference, but sometimes is worth repeating :woot:
i thought he was interested in comparing what happens at the crank with different turbo combinations on rb's, the road speed will just be a result of a bunch of other things that he might not want to change.
So basically I am looking for the best trade-off between quick spool and power output. I am just looking for turbo information, nothing else.
Edited by norwest_rumbler
cant find the graph yet but this gives you some idea...
Car : R32 GTST
Engine : Rb20det
Turbo / Supercharger : GCG RB25 hi-flowed turbo (converted to ext gate)
Mods to Note : Zorst, cooler, mangament, injectors/pump , spitfire coils, etc
Rev Limit : 8200rpm
Diff Ratio : Not sure
Dyno : Hyperdrive DD
Peak Power : 300rwhp
3000 rpm = Sub 40rwhp
3500 rpm = Sub 80rwhp
4000 rpm = Sub 100rwhp
4500 rpm = 110rwhp
I had one on my RB20 which was bloody tired (popped a few weeks later, not turbo related) and it still made decent power and was quite responsive. I think the thing should've made more power if the engine wasn't on it's last legs too. But still, 220rwkw on 1.4bar, not too shabby.
I'd love to see your dyno sheet of it being a pig, because mine completely disagrees with that.
Just the usual mods, nothing special, just turned the boost up lots :)
Note: That's an RB25 turbo, not "standard" as the sheet indicates.
Boost starts ramping up 400rpm later and ramps up at the same rate. It started making more power than the stock RB25 turbo at 3600rpm and made full boost of 1.4bar (20psi) a smidge after that. 1bar came at around 3300-3400rpm.
lots of midrange timing would explain the engine popping a week later and the good response ;)
Like these guys have mentioned...hks2510 is the way to go if maximum response is what you're after...or like troy said...see if there is a T3 flanged gtss...that would be awesome...my old 32 had a hks2535 making 237rwkw had a decent trade off between power/response...but for what you want something smaller like a 2510 is hard to ignore...
Hi Roy , T3 flanged GTSS is a new one on me but there's no physical reason why it couldn't be done .
Just so people know the RB26 and SR20 style HKS GTSS turbos are different .
Housings are different because RB26 style housings are unique to that application .
The two turbines are different GT28's , RB type 11 bladed 62T version , SR version 9 bladed 76T one .
Different compressors , RB26 type is a bit of a special 59.6mm 56T , SR type generic 60.1mm 60T GT type .
HKS do T3 flanged GT28BB turbine housings for GT2530's and these would bolt up to an SR type GTSS turbo .
They used this same housing and turbine on RB20/25 specific GT2335/2540/GTRS as well .
The old 2510 is just a 2530 with the 11 blade 62T turbine substituted , same compressor wheel .
The SR type GTSS uses the better 76T turbine with a smaller trim comp (60T vs 63T) so its slighty more biased towards the hot side than a 2510 .
IMO less exhaust manifold pressure and more ignition advance = better result .
Cheers A .
Still looking for SR20 type GTSS cartridge (CHRA) number . Dont think anyone knows ...
Also when I asked Gary about his GCG Hi Flow for the RB20 I think I remember him saying it used an RB20 rather than an RB25 turbine housing - that would make a difference in response .
Edited by discopotato03
who has more information on the t518z turbo.
i also want the best trade off for response/torque (not just figures, but so i can feel it) and power (like everyone else) but i want around 230-250rwkw, if it means im going to lag from breakfast to asshole to get 250rwkw then idont want that much, but i would like at least 230rwkw. i want the car to feel that its pulling hard(usuable power) by 3k.
its a r32 gtst
from what i mentioned earlier would the smaller exhaust housing version of the t518z be the best option?
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
