Unless the stocker is dead, nothing other than dropping compression. Its not a major drop either way.
oooodles of cars running around with 250rwkw, un-opened motors.
With the fuel quality (Shell 100 etc) there is no real need to do the old 'de-comp' from the late 90's/VL crew so you could run more boost etc without it detonating. You've got a motor 10 years newer, much nicer flowing head etc.
With the thicker gasket, no real need until your at the point of rebuild and chasing 300-350rwkw+ IMO. I believe my motor had a Tomei item after it went forged. On a relatively stock/mild setup, i'd go with factory, tried and proven and i think the cheapest option (if yours is dead)
https://www.sau.com.au/forums/topic/226281-head-gasket/#findComment-3984809
Standard head gasket is good for boost levels up to around 24psi and hp of around 600 at the wheels.
Could handle more but I've never tested one any higher
Metal gaskets were designed to be reused and to also drop compression like Nismoid said. It is a silly way to drop compression but small drops can be made this way if you had to.
https://www.sau.com.au/forums/topic/226281-head-gasket/#findComment-3985033
Also, your friends at Rajab should be able to offer some advice on the subject as they have many hi-po cars getting about.
Yeah i spoke to them. My head gasket has blown at the back of the head so i was wondering if i should get a standard or the metal.
thanks for all your advice guys.
https://www.sau.com.au/forums/topic/226281-head-gasket/#findComment-3985804
also guys i have got one more quick question. are the welsh plugs on a skyline steel or brass?
cheers
steel welsh, if you do decide to go metal make sure the surface finish is done corectley ie 50RA or better
https://www.sau.com.au/forums/topic/226281-head-gasket/#findComment-3986257
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
