$1300 final price for gt3040 turbocharger!!
paid $2300 for it.
surely someone needs an uprgade for an awesome turbo. just need your stock turbo too!! :):worship::unsure:
Edited by R33GOD
  • Replies 89
Posted Images
parts still 4 sale
gt3040 custom garrett turbo - $1300 ( stock r33 gtst turbo my way)
Apexi power fc ecu -$800!!
600cc creatd motorsport hiflowed injectors + stock injectors my way $200
Saber smokey faced air fuel gauge - $80
Tomei direct replacement fuel pump for r33 gtst -$300
HDI boost controller - $50
z32 afm with plug - $180
HKS heavy duty wastegate actuator -$ 70
Edited by R33GOD
willing to take $1200 for my garrett turbo + a stock r33 gtst turbo. needs to be in vg condition
thats a saving of over 1k for basically a new 500hp turbo in immaculate condition!!
Edited by R33GOD
