hi guys,
i want to have the option to run rwd for drag purposes, am i best off fitting a switch? if so what is the best way to do this? im assuming maybe off the relay under the bonnet as per the workshop manual.
OR
should i invest in 1 of those torque control switches where u can actually control the f/r ratio from 0/100 through to 50/50?
thanks,
marko
does anyone know i can locate those torque split switches where i can actually fine tune the ratio between front & rear?
apparently they're on ebay but i cant find them
I too am interested..
Id like to make my own.. similar to what the one in QLD is like.. but much cheaper.
http://page18.auctions.yahoo.co.jp/jp/auction/w26022938
This is what i use. It comes not only with the torque splitter but the drag adaptor as well which would be ideal for what you want. You can adjust it so you can launch 4WD but it goes straight to RWD at what ever speed you set it at.
well ive found this:
http://cgi.ebay.com.au/GTR-Torque-Split-Co...1QQcmdZViewItem
i knwo someone thats using this particular brand & he is very happy with it
I purchased one of these just a month ago and they are BRILLIANT!
Adjust from 1 (for dry weather) to 10 (absolutely pissing down) and I CANNOT break traction (I have a stock R32 GTR putting out 192kw at the wheels). However, once you want to have a bit of fun flick from 4WD to 2WD and you're running constant rear wheel drive only.
It only costs $200 and can be fitted easily yourself (if you can solder and read). Many GTR owners claim this to be the best bang-for-your-buck suspension modification that you can make.
Totally recommend it!
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
