All items located south of Adelaide, may be able to deliver.
x6 Denso 600cc injector's to suit Rb20det
=$550
x4 R32 gts-t disc's
=$40
x4 - 235x45x17" tires (on wear indicator's)
=$30 the lot or $20 a pair
x2 - 225x50x16" tires (on wear indicator's)
=$20 the pair
R32 gts-t diff (was occasionally open wheeling, perfect if you're looking to weld up a centre)
=$50
Unifilter pod (washable, comes with oil)
=$20
Stock R32 camber arms
=$20
x6 stock rb20det injector's
=$10 each or $50 the lot
Ash (0413045900)
https://www.sau.com.au/forums/topic/226867-few-bits-pieces-4-sale/
  • 4 weeks later...
what condition are the front discs in, and are the above the minimum machining size?
and any idea of postage to sydney ( again just the fronts)?
thanks
scott
thanks
scott
find out what the minimum size is in mm's and i'll measure them!
$20 for postage!
=$550
x4 R32 gts-t disc's
=$40
=$30 the lot or $20 a pair ono
=$20 the pair ono
R32 gts-t diff (center only) (was occasionally open wheeling, perfect if you're looking to weld up a centre)
=$50
=$20 ono
=$20 ono
=$10 each or $50 the lot ono
Ash (0413045900)
EDITED!
  • 5 weeks later...
  • 3 weeks later...
  • 3 weeks later...
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
