Are they N1 turbos to suite the RB26DETT?
If so, N1 Turbos came stock on the R34 GTR V-Spec II Nur's and stock max boost was 1.1 Bar = 15.9 Psi.
BTW I think you should post this in the Force Induction Threads. LOL!
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4004158
nope no bigger versions - still enough detail visible to be able to cross reference turbos
By looking at the picture, The BNR33 and BNR34 have (N1) next to it and the BNR32 has (NISMO)...
(R32 GTR's came out in N1 Versions but I was never clear if it had N1 Turbos, but I read that the engine was upgraded to R32-N1 Specifications, hence the turbos should have been upgraded to N1 turbines)
Question is, in the picture, are they R32 GTR NISMO turbos?
Any different from N1 turbos?
NISMO made turbos? They might but are made by Garrett...
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4006864
HKS make turbos ? They might but are made by Garrett...
Trust make turbos? They might but are made by Mitsubishi...
Apexi make turbos ? They might but are made by IHI...
Perhaps they simply named it nismo instead of N1 - do we know what N1 stands for? nismo is nissan's motorsport division (Nissan Motorsport International Limited)
use the pic as you will...
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4008061
Interesting. Thanks!
N1 maybe Nur Spec?
The R34 GTR V-Spec II Nur has a N1 Specification built engine in it.
Here is an overall idea,
N1 or Group N refers to a set of regulations providing 'standard' production vehicles for competition, often referred to as the "Showroom Class".
Ref - http://en.wikipedia.org/wiki/Group_N
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4009097
thanks for all the help!... those pictures help alot!
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4010228
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
