Are they N1 turbos to suite the RB26DETT?
If so, N1 Turbos came stock on the R34 GTR V-Spec II Nur's and stock max boost was 1.1 Bar = 15.9 Psi.
BTW I think you should post this in the Force Induction Threads. LOL!
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4004158
nope no bigger versions - still enough detail visible to be able to cross reference turbos
By looking at the picture, The BNR33 and BNR34 have (N1) next to it and the BNR32 has (NISMO)...
(R32 GTR's came out in N1 Versions but I was never clear if it had N1 Turbos, but I read that the engine was upgraded to R32-N1 Specifications, hence the turbos should have been upgraded to N1 turbines)
Question is, in the picture, are they R32 GTR NISMO turbos?
Any different from N1 turbos?
NISMO made turbos? They might but are made by Garrett...
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4006864
HKS make turbos ? They might but are made by Garrett...
Trust make turbos? They might but are made by Mitsubishi...
Apexi make turbos ? They might but are made by IHI...
Perhaps they simply named it nismo instead of N1 - do we know what N1 stands for? nismo is nissan's motorsport division (Nissan Motorsport International Limited)
use the pic as you will...
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4008061
Interesting. Thanks!
N1 maybe Nur Spec?
The R34 GTR V-Spec II Nur has a N1 Specification built engine in it.
Here is an overall idea,
N1 or Group N refers to a set of regulations providing 'standard' production vehicles for competition, often referred to as the "Showroom Class".
Ref - http://en.wikipedia.org/wiki/Group_N
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4009097
thanks for all the help!... those pictures help alot!
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4010228
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
