Hi Guys
I got some stuff done to my skyline during the week. FMIC, 3" Cat back zorst, High Flow Cat, 3" Dump pipe,Bigger fuel pump, Apexi air induction, Apexi Digital boost controller and then I got the Nistune to 0.9 bar of boost. I was reading in some old topics that people with same car (R34 gtt auto) same stuff done to there car and they were getting 173wrkw at stock boost. And at 0.9bar of boost I got 158wrkw. Is this the power you would expect from a R34 gtt auto?
Trent
https://www.sau.com.au/forums/topic/227476-power-for-skyline-r34-gtt-auto/
Yes the car was tuned yesturday by Hyperdrive. They used Nistune to remap the ecu.
They were saying that it was the first R34 there to use the software.
hmmmm..
doesn't sound right..
not 158
hey sell that car and buy mine. :whistling:
Edited by rice boy
Does sound a little low, though Hyperdrive do seem to have a reasonably accurate dyno (as in it tends to be lower than some) but that wouldn't be that much of a factor.
My manual R33 GTS25t managed 190rwkw with similar mods (though my boost curve isn't great).
Post up your dyno sheets and maybe we can figure it out.
Hi mate,
I have a 1998 nissan skyline gt-t auto sedan, mods are fmic, turbo back exhuast 3inch, greedy electronic boost controller, k&n pod filter. Car on 10.5psi made 189.5kw, and stock boost which was 8psi made 183.3kw. Mind you this is with std fuel pump and std comp. This is the safest level to boost a 34 running a stock ecu. As if you go past the 12psi mark they usually start to cut out thats how the std ecu's are designed. Your figures don't seem right, i would be expecting a little bit more power. Post the dyno sheet up if possible. Hope everything goes well
Cheers.
Edited by DRFT31
I would post a picture of the dyno run but last night when I was at a mates house, I was about to leave so I started the car to warm it up then and it was running for about a min then it just turned off. So I tryed to turn it back on but it wouldn't start, so I waited for about 15min came back the car started for about 30sec's this time and I couldn't get it started again so. wtf :) . So now the car is stuck at my mates house and I will need to take it back to Hyper Drive to fix it. O yeh and the Dyno Sheets are in the car so I can't get them.
Hi mate,
Cheers.
Where was the dyno done for yours, I'd be suspecting that your numbers are a fraction high.
I dont understand, I thought you lose around 30% of power from the fly through drivetrain in his case 158kw making thats 211hp at the fly making that around 150rwkw....
On my dyno sheet i got 270hp at the fly i dont have 270rwhp...
Edited by Dani Boi
It doesn't just depend on what mods you have bolted on, what about the condition of the engine?
And judging from what you said how the car wouldnt start properly before. I think your plugs might be fouled or ro0ted. Might be responsible for a proportion of the power loss? m2c.
34 GTt's are 206kw flywheel stock (take about 7 or 8 kw for auto so ~198kw) and i dont think you would lose that much to the wheels without any mods. so with those mods its definately low. Did u get ur car from ur mates yet ??
You don't lose a percentage, a drivetrain will sap a certain amount of power but that doesn't increase with power.
158rwkw does seem rather low. I made 183rwkw with a similar turbo on the same dyno.
If a tuner is giving you a dyno sheet reading flywheel horsepower yet it's a chassis dyno, it's just a guess. Ask for one at the wheels.
Edited by bubba
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
