We just held our nismo day up here and it was definitely the best track day we have had.
Had a phone call from Bunta and we hit on a plan to give you guys a chance to redeem yourselves.
Howbout you send a 5man team to our track day next year and we will reciprocate. Rules to be worked out later this year when andy and I come down for a day at Wakie.
We can accommodate, feed and water you with some good old qld hospitality And have a great days fun at the track.
Winning team gets bragging rights that over ride even the state of origin football series on the forum. For e.g. Hey blues! we kicked yourae again in the footy!....Who gives a shit qld, we handed you your arse on the track!
THink about it and dont listen to the "gunna's" I'm gunna do that and dont show up etc.
Game on Blue belly's. :thumbsup:
https://www.sau.com.au/forums/topic/227548-hey-blues-one-more-time/
  • Replies 48
if beating a qld sau member was worth the 20 hour driver from melbourne.... i'd be there.. but the bragging rights do not amount to much given it's only SAU QLD
Funnily enough there's already too many bloody mexicans who think it is worthwhile to come up here.
AND THE PRICKS WONT LEAVE
i had noticed that from the latest track day ha ha
Yeah I guess thats one modification we dont have up here so they will have the advantage at wakie. I wonder if the prehistoric neanderthals have even seen electronic timing. I bet they dont trust it. :P
It's Black Magic
actually...I'm heading up there in the next 12 months. But it should be fun will try and convince neil to bring the radical, I'll bring the boring old stocker, and we can also bring the nugget.
not sure of an exact date yet because it aint running.
I'll let y'all know when you can roll out the red carpet
sweet! let us know as soon as you can and we will have something planned!
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
