hey peoples... my car(R33 gts-t 4door) is coming up to 95k's so im starting to get abit of information about the 100k service as this is my first car that has needed this, it's only got a exhaust and pod if that helps...was just wondering if anyone has any good comments or recommendations for a workshop in brisbane(southside would be best but any welcome)..rough ballpark prices would be appreciated..thanks :P
https://www.sau.com.au/forums/topic/227568-100k-service-for-r33-gts-t/
if you want to do it properly, ring round some workshops and get a quote to do; timing belt, tensioner bearing, idler bearing, bottom air con pulley bearing, water pump and cam seals! then normal stuff like belts etc. Worth fitting an adjustable cam gear while its all apart if you have future plans for the car too. hope this helps
AMEC - Can you give a breif listing of what is included in your 100k services for $953
sure :laugh:
our R33 GTST 100K service includes:
Idler & Tension Bearing
Tensioner Spring
Cam Seals & Front Main Seal
Genuine Nissan Timing Belt
Genuine Nissan Water Pump
Labour and Fluids
Kudos Motorsports offer a few 100 000km service packages (3 I believe) for the R33. So if you wanna purchase parts and find somebody to install here are the links to all 3 packages by Kudos.
Kudos Basic Kit
Kudos HD Kit
Kudos HD+ Kit
Cheers.
hey Amec, just outta curiosity, i have a 34 gtt and im comin up to my 100k service too, would the cost be the same for my car since it too is an RB25DET? also, is it possible for you to guess how much extra it would cost to get a rocker cover gasket fixed at the same time? hoping to save on a bit of labour doing it then.
Ill also make sure i shoot a call ur way too ECC
Edited by RusH_
yep 100K service will be the same price $953 including parts and labour :blink:
will do the rocker cover gasket for $85 + cost of the gasket.
rush - same price champ
wont get in price wars on forums or anything as it is not very professional or ethical , so give me a call if you want labour quote on the r/c gasket :P
Good call, this forum eats up and spits out workshops that try to get work off of here.
Do some searchs on workshops that have tried to help members in the past, most of them have moved on from here never to return.
You will be the flavour of the month while you are giving them forum member discounts, then another shop will undercut you to get the work and BOOM you were a rip-off and you will get bagged and dumped.
Not all members of this forum are users and abusers, but a few bad apples as they.
With AMEC, not only will you get good service and value, but we also have the unique claim where the mananger regularly competes in circuit racing and has won the Queesnland Raceway sprint series in a race car built by our workshop. All on the same VG30DETT motor we built back in Feb 2006 and she is still going strong @ 24 psi.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
