Hi Guys,
Okay, i drove my car for 30minutes and went to fill up at the servo. When i got there i popped the hood to check the oil level as i do every week.
Tonight i was shocked to see the oil level was waaay beyond full! about 1/4 of the way up the dipstick! So i wiped it clean and stuck it in again(with the engine still running).
The result was the same...
Why would this be happening? I am starting to stress that this could be a more serious problem but i dont want to take it to the mechanic and ask before i get some advice on here since im afraid they will try to tell me its worse than what it actually is.
Any help is appreciated. Thanks.
https://www.sau.com.au/forums/topic/227579-is-this-something-to-worry-about/
Hey sean,
I just checked it then with the engine off, and the oil level is beautiful not too high not too low :P
Don't understand about the oil sloshing around while i drive? how would i tell?
Oil pressure and temp gauge's are within the normal ranges.
Is this all normal?
Thanks again.
Hey sean,
Is this all normal?
Thanks again.
As long as you ain't taking the mickey, here's why.
The internals are rotating at a thousand revs at idle. The crank, rods, pistons are throwing off oil that has lubricated them as well as oil draining from the head oil returns. This all ends up back down in the sump along with frothy aerated oil from the turbos. The oil level will not be true as it will be mixed with air and sloshed around in the bottom too. It may bubble into the dipstick tube and run up the dipstick to give a false reading.
Cheers.
wtf is ur problem?
i am new to this scene and i am overcautious about my GTR.
My old car never used to do this even after it was hot, so that is why i was wondering.
I didn't realize that asking a f@*&^ing question was cause for being a smart arse...
As for GTRsean, thanks thats what i thought, but just wanted confirmation that nothing was wrong internally.
Edited by GTR-PWR
Lol Deren, PS i meant to be checked like that.
Hey, I understand where Harry is coming from, when I tell some mechanics I work in IT, drop off the car dressed in a suit and tie, clean all the grease and other shit off me, and go off for a meeting with clients, they sometimes talk to me like I am blone, 18 yrs old, and never lifted the bonnet on a car before.
A lot of people dont actually know their cars as well as others do, but they still love them as much.
Remember people, we all started in this scene somewhere, for me it was when I was 10, and saw what Nissan's godzilla could do at Bathurst, from there I knew the potential of cars with build quality.
For others it's when they decide to bite the bullet and give things a try, and get a Godzilla to see what the hype is for, at least Harry is trying to keep an eye on the car, and care for it.
B.
Thanks Brian, well said mate.
My strong passion/obsession with my car is one which cant be easily described and i am at trying to do everything i can to learn more about it mechanically and how to treat it properly.
We all need to start somewhere, keep in mind 3 months ago i was driving a VP Executive AUTO and had driven a manual car maybe two times before in my entire life.
I am also very passionate about my GTR. Only gotta read my GTR thread to understand that! Im very fussy and very pedantic. If you or anyone else ever needs any help with your car (especially GTR's) please do not hesitate to contact me, as a mechanic i am more than happy to help where i can.
Good move with the VP :) Buying a GTR was always my dream too.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
