hi sturbs
there are some tutorials in the DIY section that should explain it as the rear doors will be pretty similar to the fronts.
the nuts and bolts of it is....
remove the screws located on the bottom side and rear edge of the door trim. probably 4-5 screws.
there is probably another screw somewhere near the handle underneath a cap of some sort.
the door handle surround can be pried off gently with a screwdriver but if you gently pull on the now loose door surround the the plastic door handle surround should pop straight off without any marks.
you should be able to get to the speaker now.
i don't have time to get pics atm but hopefully this helps.
hi sturbs
Thanks mate
Much appreciated
Doing it 2day so any dramas ill let u know. Im pretty good with that sort of thing so there shouldnt be
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
