I recently had a 3" dump fitted and the original heat shield over the turbo and dump was removed.
Should I get some exhaust wrap on the dump?
How effective is exhaust wrap in reducing under bonnet temps?
www.flyn.com.au is selling 6m of fibreglass exhaust wrap for $48. Anybody using this stuff? Is this stuff any good?
https://www.sau.com.au/forums/topic/22793-should-i-be-using-exhaust-wrap/
  • Replies 55
Im looking into doing the same thing this coming week fo rmy new dump pipe. An estimate from an exhasut shop was that i would need approx 10m to do a 3" dump pipe. This would allow the dump/front pipe to be covered past the bottom of the firewall.
Add to this the expense of the clips to secure in place, and the coating to protect from the elements and i have decided to get the dump pipe ceramic coated. At approx $80 it is neater and perhaps better value, i cant say which works better as i have never used the exhaust wrap.
I have had my exhaust manifold and exhasut housing done by Competition Coatings and i have been happy with their work.
10mtrs was for dump and front pipe, as the front pipe normaly had a heat shield that goes all the way down to the cat.
My thinking is they are shielded for a reason so want to do the same to be sure that nothing on the firewall/floorpan is damaged by the hot exhaust. (My old R31 used to cook the floorpan as i had the exhuast tucked up nicely to ensure good ground clearance.
With the exhaust housing of the turbine after a 30min drive you can hold your hand about 1" from the housing for about 15sec before things start to get hot, so would seem to be working. I wish i could have tested it with a thermocouple before/after but didnt want to have to take the turbo off after having instaled it as the coating takes about 4-5 days.
I'd definately recommend wrapping the dump. I'm having mine ceramic coated, then wrapped. The ceramic coating alone is enough to allow you to touch the dump/or exhaust manifold without burning yourself.
The secondary advantage to keeping the heat trapped in the exhaust gasses is that they help spool the turbo quicker:D
I imagine that it not only allows the turbo to spool quicker but it MAY also reduce back pressure as the gas has a faster velocity hence it gets out of there quicker allowing the motor to breathe a little better in the higher rev's?!?! Maybe... :)
Depends what material you use. I have heard of a number of stainless manifold cracking, but usually due to the poor choice in stainless type (there are many type with different compositions). My manifold is made from steam pipe, it has a much greater thermal mass, and therefore isn't prone to cracking like the thin-walled stainless.
I had a 3" dump of mild steel and the engine bay got bloody hot, so hot that I got paranoid so I wrapped it, which made a huge difference to underbonnet temps.
Have now fitted a stainless ceramic coated dump, and I dont think it is quite as cool as the heat wrapped mild steel, so I will be heat wrapping it aswell.
Having higher velocity in the exhaust, apart from spooling up the turbo quicker, can aid in cylinder scavenging. Also increased velocity decreases pressure, and back pressure is not your friend either:)
Bottom line, if it makes the car go faster/harder, its all good. People have been coating and wrapping manifolds/dumps/turbines for a long time for good reason.
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
