I recently had a 3" dump fitted and the original heat shield over the turbo and dump was removed.
Should I get some exhaust wrap on the dump?
How effective is exhaust wrap in reducing under bonnet temps?
www.flyn.com.au is selling 6m of fibreglass exhaust wrap for $48. Anybody using this stuff? Is this stuff any good?
https://www.sau.com.au/forums/topic/22793-should-i-be-using-exhaust-wrap/
  • Replies 55
Im looking into doing the same thing this coming week fo rmy new dump pipe. An estimate from an exhasut shop was that i would need approx 10m to do a 3" dump pipe. This would allow the dump/front pipe to be covered past the bottom of the firewall.
Add to this the expense of the clips to secure in place, and the coating to protect from the elements and i have decided to get the dump pipe ceramic coated. At approx $80 it is neater and perhaps better value, i cant say which works better as i have never used the exhaust wrap.
I have had my exhaust manifold and exhasut housing done by Competition Coatings and i have been happy with their work.
10mtrs was for dump and front pipe, as the front pipe normaly had a heat shield that goes all the way down to the cat.
My thinking is they are shielded for a reason so want to do the same to be sure that nothing on the firewall/floorpan is damaged by the hot exhaust. (My old R31 used to cook the floorpan as i had the exhuast tucked up nicely to ensure good ground clearance.
With the exhaust housing of the turbine after a 30min drive you can hold your hand about 1" from the housing for about 15sec before things start to get hot, so would seem to be working. I wish i could have tested it with a thermocouple before/after but didnt want to have to take the turbo off after having instaled it as the coating takes about 4-5 days.
I'd definately recommend wrapping the dump. I'm having mine ceramic coated, then wrapped. The ceramic coating alone is enough to allow you to touch the dump/or exhaust manifold without burning yourself.
The secondary advantage to keeping the heat trapped in the exhaust gasses is that they help spool the turbo quicker:D
I imagine that it not only allows the turbo to spool quicker but it MAY also reduce back pressure as the gas has a faster velocity hence it gets out of there quicker allowing the motor to breathe a little better in the higher rev's?!?! Maybe... :)
Depends what material you use. I have heard of a number of stainless manifold cracking, but usually due to the poor choice in stainless type (there are many type with different compositions). My manifold is made from steam pipe, it has a much greater thermal mass, and therefore isn't prone to cracking like the thin-walled stainless.
I had a 3" dump of mild steel and the engine bay got bloody hot, so hot that I got paranoid so I wrapped it, which made a huge difference to underbonnet temps.
Have now fitted a stainless ceramic coated dump, and I dont think it is quite as cool as the heat wrapped mild steel, so I will be heat wrapping it aswell.
Having higher velocity in the exhaust, apart from spooling up the turbo quicker, can aid in cylinder scavenging. Also increased velocity decreases pressure, and back pressure is not your friend either:)
Bottom line, if it makes the car go faster/harder, its all good. People have been coating and wrapping manifolds/dumps/turbines for a long time for good reason.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
