I think the lack of chicaines is going to hurt the emo's and wrx's. Rossarden is going to be really fast without those chicains, will be lots of time to make up with good notes, as it will be bloody scary for most.
Totally agree, if the two girls in the Unique Evo were in the main game, well, there'd be something wrong if they weren't giving Jeff a real good run for his money in E Mod. Reading through the list I'm actually suprised how relatively uncompetetive it looks! Why did Shaw pull out?
I wouldn't be too concerned for the Evo's and STi's Benny, from some of the figures I hear the things make when nicely tuned on E85 it's actually the Lambo and Porsche guys that should be worried! lol
And I totally agree on Rossarden, I'd be running full peak coming over that crest without a chicane there as a buffer :D I hope everyone has good brakes!
I think shaw was scared off by this wepon http://www.targa.org.au/Competitors/profil...0Early%20Modern . E Mod dosn't look like it'll get any media coverage at this rate. we'll have to create some media interest for 2011 :D
still don't know if E85 is worth it, you've got more power, but your lugging extra weight around. I've heard some people say they'd need a 120l in a emo to run it.
One of my relitive is running a block of flats (volvo 242) in the rookie classic, i've told him not to crash, as the greens will kill him from putting such a big hole in the scenery :D
Well Im doing Targa now woo yeh! Except I'll be one of the first cars on the road every day and not appear in the results...
Navving for a bloke in the Zero Car, its a Mazda 6 Sport Diesel being supplied by Mazda for the event. Should be a bit of fun, no pressure and still get a buzz :cool: and importantly it will get me back on notes in preparation for Mt. Stuart Sprint with Benny in June. It has been 12 months since I looked at pace notes and I pulled some out the other day and began scratching my head. What tha fudge does that mean :ermm:
Oh and I didn't want to go off topic in the the other thread about Serge's R34, but am I right in saying that E85 will be compulsary from 2011??? Im sure I read it somewhere...
If it were the case with Arrowsmith maybe they could put a pitstop in half way and make it F1 style (IE you can win it or lose it in the pits Lol!)
Good to see you're in Timmy, even if it's in one of those Mazda things :thumbsup:
And good to see the smack down talk has started, albeit a little late.
I'm back in with the llama in the new & improved ATTKD Select SP- Go Car 803!
Should be an interesting Targa, some of my local mates are already predicting it will be wet?
Totally agree, if the two girls in the Unique Evo were in the main game, well, there'd be something wrong if they weren't giving Jeff a real good run for his money in E Mod. ...
Oi....just 'cos we're good looking AND fast! :P
Seriously though, have tried numerous times dangling the full Targa carrot in front of Handbags, but to no avail. "You only get to have a crack at Rookie once" says he. Well experience says I get to do it twice! :P
Fingers crossed we can set the place alight (so to speak) and show some form on the results page come Thursday night.
Kel, are you guys staying at the Penny Royal again?
what trick bits does a ATTKD Select SP have?
I'd tell you Ben, but then I'd have to kill you :P
Lucky Stu came good with the info
Yep Dan, staying at Penny Royale again - is that where you are?
We should organise an SAU catch up, everyone's schedules permitting?
Yeah it's our base again :-)
SAU catchup definately!
Edited by rexdan
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
