Caught up with YT this morning to pick up some old bits he had left over from the R34 days and he says the Super Alphabet is going to be ok abeit with a weight penalty which I thought was interesting.
Also seems the Skelta's will get a weight penalty too and have to lose the S/C.
Stuart, thanks for clarifying.
Could you also please clarify the rules on gearboxes. Specifically, I'd like to know what you a free to change and what is not. Can we change gear sets provided the same casing, shifting pattern, and number of gears is maintained? Can helical gears be swapped to straight cut, and do the ratios have to remain the same? Failing that, can the lower gear ratios be changed if the the final drive (ie toptop gear) remains the same.
Specifically, I am interested in early modern skyline (LMS I think), and there is no mention of gearboxes until MS. My understanding from previous years was that there was some limited freedoms with respect to gear sets.
As far as I can read Mark the following ONLY apply to MS cars
M19. Gearbox / Transmission / Final Drive
a) The clutch is free.
b) Flywheel is free.
c) The casings and housings must be the same as originally fitted to the vehicle.
d) The number of forward gears must be standard; otherwise the internal components are free.
e) The gear change mechanisms must be as originally specified for the vehicle, other than that shortened or ‘quick’ shifters which do not result in
modification to the casings or housings are permitted. Sequential shift mechanisms are not permitted.
f) The internal components of the differential, axles and drive shafts, are free.
g) Live rear axle equipped vehicles may be modified to incorporate floating rear hubs.
So for LMS the above must remain as per factory specification
That's how I read it too, but from how I read the rules, Z tune and ATTKD and possible 400R are out, but according to Stuart are not, so I just don't know what to go by. I'm not arguing the rules, it's just better to get official clarification from Stuart.
Even if gearboxes are factory, what is the ruling on OEM parts? Can I put a gear set with exactly the same ratios and format (keep them helical not straight), ie only cheaper and/or stronger, or do I have to use genuine Nissan parts?
I think the new rules are great, but I'm not sure I understand the exclusions.
If you read it to the letter, then this also applies to the clutch, which means the skylines would be back to the factory clutch plates which are organic and wear very quickly. Doubt they would even last the whole event.
Under the old rules, as long as it was the same function, ie single plate, you could change for an aftermarket clutch plate, so at least something that would last. Gives no advantage in performance, but at least would last.
Again, I think we need some confirmation here before I start ripping the car apart.
If it is a case of having to be all factory original parts, then we are worse off than before, with the 400R having all sorts of parts advantages, and we go backwards on basic durability parts.
Yes, Steve Glenney is one of the instructors, spoke to Mick who is running the show and it sounds good. I think I'll be doing it. Here is link for outline of the day
http://www.rexnet.com.au/forum/index.php?/...a-training-day/
Brendan Reeves is also involved... One thing from these tutorials is the nav stuff. Having a calm nav because they understand what is required can be worth about 1/2sec/km I reckon
Just doing a wooster and dropping in to the other side for a quick peek. Seems the fallout from the showroom change is more a 4wd thing. Guess the no cat rule last year wasnt quite enough to get the 2wd's to the front. I am glad we had a run in the good old days.
TT
Haha will the fence jokes ever stop!?!?!? :D haha
No chance Ben- it's way too much fun ;)
Speaking of fun- I won't be having any unless I can sort out a new seat.
Yep Handley & Handley looks to be no go for THC.
Anyone know of anyone looking for a nav?
Can't remember who was up on the embankment on the Silverdome this year furiously applying rain-x or trying anything and everything to prevent the screen fogging on day one. Del over on the ip forum tells me he might possibly be able to assist if you want to outlay a few sheckels and avoid the 12v dryers and not so magic potions, never know, might even get snow in November too!
Guilty as charged, and for the first time, rain-x didn't work well enough.
Talk about wet, day 5 on Aerosmith was the worst.
Ah, was thinking about a dark coloured car up the very top of the rise, asked us what we were doing, other than running around like headless chooks. Now I think of it, more than a couple of cars up there.
Aerosmith is pretty bad, although that Tyler bloke with a face like a smashed crab can pull some women! That longish stage on day 5 was almost as revolting, conga lines of cars overtaking then finding no taillights to follow, hard on the picks, repeat to end of stage. :)
Not sure there is skyline data there, suppose the first prerequisite of going at any pace is seeing the road though, screens are supposed to be around $500.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
