This thread has been a consistent delivery of lols, very impressed :D
Thinking i might start to Nav, i don't earn the bucks like you blokes, be a fun way to get into it. Plus I'm a good passenger, especially on dirt roads in WRXs ha ha.
I started as a nav for a mate, we had a ball until family stepped in the way. Then I navved for another dude, then he quite it too. I couldn't turn my back on it, so I decided to turn tricks on weekends to help fund it. Kind of painful having to turn Benson away all the time, I told him I don't know how many times that I don't roll that way but he's insistent. Maybe he just sees me as a challenge?
Just one... you're in a class of your own Woo!!
Poof. Aren't you still overseas or somethin? If not, GO BACK!
Treat 'em mean keep 'em keen?
Yes mate, back and full steam into it... big targa season ahead and plenty of teams doing work in the off season and everyone beating on the door.
White Hot, Supaloc, VIP, Just Jap and Yellow Racing to name only a few have all have plenty of work underway.
More new bits arrivng for the RX-7 too, and confirmed my nav while I was away for Rally Tas 2012 too!
Your Nav? Hang on! What have I missed? Can you drives withs gears?
Supaloc, new V12 thing innit? Reading the tests on them, they sound absolutely amazing, a huge leap forward from the Murci, the last actual Italian designed one.
Was speaking to Baldrick on the weekend, and he recons that YT has a new Gallardo, and weeks is running Murci and not the Aventadore. But it's from Baldrick so they could still rock up in anything.
Lolz
But, Big John did get a new Gallardo it turned up during targa this year.
Aventadore, maybe its a hybrid Commoghini?
Yellow Racing - ZR1?? :)
They went to the States recently and track tested a whole bunch of stuff from Ferrari to Vettes..... not sure what the preference was. I do recall one of them telling me that the Z06 was more suitable to racing than the ZR1. Unsure why though.
Same for Z06 though. They actually took a car to my mate across the road who does lots of cages (and many of theirs prior), he suggested that the entire car would need to come apart to do it properly (basically make a self supporting steel cage in and undr the car), but they decided to take it away and have it done elsewhere. Not sure of the outcome.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
