HI all i just pulled my intercooler off to give it a polish..
When i took it off and looked in one end there was some oil there so i sat it end to end with a container
underneath and i got about 20 - 25ml of oil after about 1 hour of it sitting there..
Cooler has been on the car for abit over two years..
would this just be a normal amount of blow by or is something wrong??
Cheers
https://www.sau.com.au/forums/topic/228077-oil-in-ther-intercooler-help/
If it's been on for over 2 years, you get some oil mist from the cam covers/rockers that gets vented back to the intake side. It hits the intercooler piping, cools and condenses.
If you have plenty of mods and you've upped the boost and religiously give it some, its normal and thats why you run an oil catch can.
If you drive like Miss Daisy and your car is std then it could be rebuild time.
Was it all oil, or was it a bit white and had some water in it?
Hey it was all oil.. ive looked at the turbo and their is no oil on the inlet side or any shaft play.. it all seems good..
i do have it running at 6- 12psi and it does get driven hard from time to time.. ive had a catch can in it for around 6 months and thier is a few drops of oil in it
so hopefully it was just my cooler acting as an expensive catch can.. only time will tell i guees as its clean now and ill check again in a few months
hopefully the catch can solved it..
Corey
Edited by sIIgtst
could be your turbo seal starting to go ive had that problem and it went on the exhaust side so after a fair bit of driving it would seem like im doing burnouts because of the burning oil :-p. also where is your pcv plumbed into if its even plumbed in. i would go along the lines of running an atmospheric catch can for a while and see if ya got any oil in the intercooler after. if results show you aint got any oil in your intercooler then i would go comp check to see the state of the piston rings :-) if you still got oil in your intercooler then yeh prolly a turbo ;-p
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
