Can anyone tell me the specifications or link me to them for a r33 Series 2 GTS with a RB25 engine in it
before i get flamed i have searched and come up empty
and also googled but there is not much on the internet about the GTS'
Any help would be greatly appreciated
thanks :D
https://www.sau.com.au/forums/topic/228198-skyline-specifications/
thanks :D
What are the specifications of the RB series engine?
RB series of engine
20 / 25 / 26 capacity (20~1998cc / 25~2497cc / 26~2597cc)
(D) Double Overhead Cam (or DOHC)
(E) EFI (Electronic fuel injection)
(T) / (TT) Turbo / twin turbo
RB20E 97kw@5600rpm 172Nm@4400rpm
RB20DE 116kw@6400rpm 184Nm@5200rpm
RB20DET (Red top) 134kw@5600rpm 225Nm@4400rpm
RB20DET (Silver top) 160kw@6400rpm 263Nm@3200rpm
RB25DE 142kw@6400rpm 231Nm@4800rpm
RB25DET 187kw@6400rpm 295Nm@4800rpm
RB26DETT 208kw@6800rpm 368Nm@4400rpm
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
