Item:
RB20 AP engineering Power FC + Hand commander
Unknown
Condition:
Perfect
Price:
$1,600 + postage
To Fit: (What car)
RB20DET
R32
A31
South eastern suburbs, Melbourne
Contact:
PM
Call/SMS 0416 623 381
Comments:
Item is a Apexi Power FC, AP engineering version to suit RB20 with hand commander
Its in perfect working order and in very good condition
Power FC is currently tuned for an RB20 running GTR injectors, Z32 AFM, HKS2535 and fuel pump. It’s been tuned by TRENT at STATUS TUNING and is making 200rwkw +
Straight plug and play computer for an RB20 loom, can also be used on an RB25 in R32 if you are using the RB20 loom
Very rare and hard to come by so don’t miss out on a genuine offer
Willing to post anywhere in Australia at buyers expense
Thanks
pfc looks good can ya drop it a hole heap :( i buy it if it a bargin :)
haha but its a bargain already!!
well the car was sold yesterday so this Power FC is no longer required
Make me a REASONABLE offer as I need it gone
Frink: I take it from that little impressed noise that you are
interested in purchasing that matter transporter, sir.
Homer: Ah erm, two bucks!? And it only transports matter!? Well,
uh, I'll give you 35 cents.
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
