that figure of 457awkw is aligned with what my tuner advised i could achieve if i switched to e85.
what exhuast diameter are u running?
That was at 20psi... will update when I get some more fuel flow
Exhaust is twin 75mm into 90mm-100mm(not sure). Center muffler 90-100mm and 5" internal rear round cannon. Primaries are long....past the gearbox up to the uni I think. No cats
  • Replies 107
Posted Images
Did I read that right back on the previous page where you said 89mm bore?
Based on my experiences with machining and sleeving RB26 blocks, the outer diameter of the cylinders tend to break away when bored to 92mm which is the necessary bore size for the OD of the sleeves.
Admittedly I only have a little RB30 experience but does the RB30 block have thicker cylinders, say around 94-95mm? If so they would support a dry sleeve very easily with an 89mm bore.
Or have you done some very radical work in order to allow the block to support a wet type sleeve? I investigated doing this as well with the 26 block, and Darton told me the block wouldnt support a wet sleeve and retain good strength (I presume unless extra measures were taken). I guess with enough grout filling the block would become sturdy enough anyway.
I had thoughts of using a stepped sleeve, that is say 95mm OD at the top, and then 92mm from 1/2 way down the sleeve to the bottom. The theory being that this would give the cylinder strength where its needed, close to the combustion chamber end of the cylinder. While keeping the block intact enough to not compromise the bottom end rigidity. Then with a 1/2 grout fill it would still be pretty much bullet proof block, and support an 89mm bore.
Sorry this is off topic, but you seem to have solved your turbo choice situation... and you have a very interesting engine that provokes me to think of ways to add more capacity to the RB.
Edit...
89 x 87.7 = 3275cc!
Edited by GTRNUR
Had sooooo much fun at Mallala. Was happy to know that the car was faster in some parts than the Lamborghini (very similar straight line but faster in the twisties)
search youtube for : Mallala 14th Aug 2010. R33 GTR RB26/32DETT 716hp playing with Lamborghini
S**t I am surprised you even went out... the weather kept me away!
weather was horrible in the morning but dried up for a couple of sessions. I have some in car footage but it doesnt look to great. time to invest in a better camera i think
sounds nice & beefy!
if u get any more footage, pls add it to your thread
Keep the thread updated as to when you are heading out to Mallala again.
Good effort.
Will do, In all I was happy with how the car performed. I'm off the Collinsgrove Hill Climb on the 28th Aug...will be fun to get some anti-lag launches happening. I cracked a disc rotor yesterday at the track so looking at my options atm...
Not sure on what pads. Want a street/track pad. Obviuosly the best of both worlds...no squeal, low dust, low wear and high friction CoE..
Hawk DTC 60-70? may be noisy
Very nice setup & power BoostdR .
Have you looked at the Endless MX72 pads.. they seem excellent in my short experience with them, no squeal from them , excellent bite from cold & hot ..low dust.
The Angle on the Camera is not optimal, but here it is anywho
I went with Intima SR pads which are also a dual purpose street/track pad. Also grabbed some DBA slotted rotors, including pads $599
NON METALLIC ORGANIC ARAMID FIBRE MATERIALS (DON'T CHEW INTO ROTORS)
High thermal stablility from 0 to 700 degC !
Average 0.4µ to 0.5µ@ 700degC
Typical application: Performance Street and Circuit Track use.
LATEST TECHNOLOGY MATERIALS
These pads are formulated to take a thrashing. Made from extreme temperature, organic aramid fibre materials that don't chew up your disc rotors.
Intima is one of the largest Performance Brake Pad Suppliers to the Japanese Market. We stock a range of Street Race Series performance brake pads for Japanese and European performance vehicles with better specifications & performance as other big-name expensive pads but at much less cost.
One thing to note about cars; they are like women in many ways. Single, hot, sane - pick only two.
Quite the same with brakes really. Your not going to get something that works great for both street and track that doesnt squeal/eat rotors/have low dust. Pick two, be done with it.
For me brake dust is like war paint :D When real drivers see an immaculate car with crazy brake dust they know you mean business. My fav was washing the car the day prior (exhibiting some pride) and being told off by the old man for the amount of brake dust and bug guts the next morning :P
+1
Not to mention the semi slicks with the rubber that looks like its been boiled!
For me brake dust is like war paint ;) When real drivers see an immaculate car with crazy brake dust they know you mean business. My fav was washing the car the day prior (exhibiting some pride) and being told off by the old man for the amount of brake dust and bug guts the next morning :)
haha, I like it. Unfortunately I have had the squeally pads before and absolutely hate it...must be getting old(32). I would prefer to replace the pads more often to be honest. I will let you guys know how the pads go and update you and on the Brakes/Suspension thread.
lol u remind me of my mate with his mazda mps - he dumps the clutch all the time & i ask him why?
to be honest ive never seen anyone do that in gtr whilst rolling, on launch im all for it though ;)
sounds tough :)
Edited by Marko R1
+1
With their remains scattered from the budflaps as far as the bootspoiler.
Life at its best ;)
Sorry OP, back to topic!
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
