I have put this in the wanted section as well but I thought I may have some luck in the ACT section:
I may be dreaming but I am looking for the following:
R33 GTS-T Series 1 (Series 2 is fine but no-one will have one at the price I am willing to pay :-))
Black
Manual
Lowish k's
Minor Mods to engine
Supsension mods (will be an ocasional track car)
Immaculate Condition
Preferable in ACT/NSW
willing to pay up to $20 grand.
cheers
https://www.sau.com.au/forums/topic/22846-wtb-r33-gts-t-black/
considered importing? I'm sure you have....just offering ideas :D
since you know what u want, an importer would probably be able to show you about 10 cars a week to choose from, that fit your specs exactly..
although, not sure if the "minor mods" would have to come off with the new laws...
or you could go for stockish and do the minor mods on yourself (a stockish one would prolly only cost u around $15k for a series 1)
Raven,
If you haven't already, check out www.prestigemotorsport.com, they'vr got FOB imports coming in weekly, at very good prices. They've also got email updates - they send u info on cars through email based on your preferences
Here's one: http://www.prestigemotorsport.com.au/au/st...sp?StockID=1225
1995 Nissan Skyline R33 Gts-t Type M turbo
5 speed
90,000 kms
Black
3" sports exhaust
Factory option bodykit with Hasemi front grille
Addzest CD and tape unit
Aftermarket clutch
HKS turbo timer
Auction Grade 4.0/5, $16 100
Originally posted by raven
My R30 has now gone to a happy new owner and I am going to need to get a car fairly soon so I cant wait the length of time needed to import and then comply.
ahh fair enough... i did think after i posted that, that time might be an issue ;)
good luck! my only only other suggestion is to try the trading post online, always seems to be a shiteload for sale in there.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
