Just a quick intro on my ride http://www.skylinesaustralia.com/forums/Hr31-Gts-t228525.html
I have been reading thru this section and partly thru the (167pages of the r33 rb25-30) thread for a few weeks, I have been inspired to do something different with my car.
At home in the garage I have a R33 S2 RB25DET and a R31 S3 Rb30E
I want to build a 25-30 NA, to plonk into the HR31.
I need some recommendations on building a high compression NA hybrid.
What I plan for the block so far, full strip down clean etc. hone, new big end bearings main bearings, if in good condition re use rods, new bolts etc. but unsure weather to use rb30 pistons, balance crank.
Basically give the block a freshen up.
Need some advise on combination of OEM pistons to use with head gasket to get a high CR (9:1 or close?) for throttle response, head shaved etc.
There seems to be so much wealth of knowledge and experience here any help or tips is much appreciated.
https://www.sau.com.au/forums/topic/228529-rb25-30de-into-hr31/
What would a more realistic CR for a NA be?
I was thinking of leaving the VVL head functional.
I reasearched the 26 ITB set up it would be definatly the top choice, however i would like to get the engine together then look at more development in the future. for now sticking with a custom plenum and single TB.
Gonna run standard R33 ECU and on 98RON petrol.
Im using;
RB25DET head, RB30e Block, RB30e Pistons.
This should give an approx CR of 8.3-1
Just not sure on head gasket, will prob use a RB30
I will have the block shaved to Xmm to increase CR.
My question is how many Xmm to shave to increase CR to a good level for NA. taking into account pump fuel and standard ECU?
Edited by GTS_Retro
Not trying to knock what you are doing, but just remember that it is unlikely you will make more than 160rwkw, which is easily achievable with any of the turbo ortions. I would take this into account when building it, and allow for the fact that you may want to turbo it in the future.
Well my initial plan was to go turbo i have the 25mani and turbo. but i just wanted the simplicity of NA. I thought 160kw more guts from down low and throttle responce would still make some fun in the 31.
Im still open to beeing talked into turbo..
So what ecu would people reccomend to use as i have just read that the 33 can not be retuned,, is that correct?
power-fc, otherwise late model SAFC with the oem ecu, all depends on how simple you keep it.
my first motor was one of these in an aus spec 31, mid range is great. Used rb25de non turbo pistons and ran off the OEM ecu entirely. It was a fairly basic setup but just hi comp with hacked up rb30 extractors to suit the 25 head.
Any idea on what kw it made?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
