Item: Kenwood KDC-X7006U Car CD Tuner with USB
Age: N/A
Condition: Very Good
Price: $150
Contact: PM
Comments:
Very Good Condition..
Comes with remote and Headunit.
No Box/Manual..
Kenwood KDC-X7006U General Features
Flip-down Detachable Faceplate
8 Tone Mono Full dot FL Display
High Speed iPod Direct Connection with optional unit
Security Code function & DSI
Rotary Encoder & Multi Control Wheel for Easy Operation
Key Illumination (Blue)
Spectrum Analyser
Auto Dimmer Function (on/off)
Digital Clock (24H)
Display Blackout Function for the Best Quality Sound Output
Display Off mode function
Remote Control Unit supplied (with Audio & Dual Zone Control)
2-way Telephone Mute
Audio/Video Features
Maximum Output Power: 50W x 4 (MOSFET Power IC)
3 Preouts with 4V Pre-output Level (F+R+S)
Subwoofer Level & Low Pass Filter Adjustable
Built-in Amp Mute function
System E’s+ (Built-in HPF & LPF)
System Q-Ex: Preset & Full Manual Sound Control
Separate Bass/ Mid range/ Treble Control & Tone Memory
AUX Input (Rear)
Dual Zone Source & Volume Control
Fader & Loudness Control
Attenuator (-20dB) with Smooth Volume Return
Installer & Backup Memory (for Audio Settings)
External Media Features
Dual External Media Control Capability with optional unit
Additional AUX input with optional unit
DNPS (Disc Name Presets) with Compatible CD Changers
CD Text Ready with Compatible CD Changers
Direct Access with Remote
Random/Repeat/Scan Play (Disc/Track)
Bluetooth Hands-free ready with optional unit
Tuner Features
FM/AM 24 Station Presets (18FM/6AM)
AME (Automatic Memory Entry)
Up/Down Seek Tuning
Station Name Presets
Selectable Channel Spacing
CD Features
KENWOOD Music Editor (Kenwood’s New PC Application) supplied
AAC (Advanced Audio Codec) Files Playback
WAV / WMA / MP3 Files Playback with ID-3 Tag Display
Multi-session Disc Playback
Folder & File Name Manual Search Function whilst playing Audio
High Performance 24bit D/A Converter (Wolfson)
0-bit Mute
CD Text Ready
CD-R/RW Compatible
Supreme
USB Features
USB Interface Ready
iPod (2wire) Direct Connectivity with optional cable
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
